Forums >> Revit Building >> Technical Support >> Door Marks linked to Room Numbers
Sat, Feb 16, 2013 at 6:23:06 PM | Door Marks linked to Room Numbers
JMBknvc
JMBknvc Avatar
Project Manager Request:
When you insert a door, that the door number (mark) is linked to the room number. Example, when you placed a door in Room 100, the door number would automatically come in as 100. I already see an issue when more that one door is placed in the room, normally the numbering would be 100A, 100B and etc... Do not know if this can be done, any information would be appreciated.
Mon, Feb 18, 2013 at 7:16:30 AM | Door Marks linked to Room Numbers
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
You can change your door numbers to whatever you want after you place it
Mon, Feb 18, 2013 at 7:39:55 AM | Door Marks linked to Room Numbers
Door numbers are set to be sequential upon placement.  As teafoe says, they can be renumbered and you can find apps to help you renumber them.
Doors do have from to properties and they can be controlled based on placement.  See my attached images.
Mon, Feb 18, 2013 at 10:49:47 AM | JMBknvc
alfmedina
alfmedina Avatar
4 Stars: 8 Votes
Quoting JMBknvc from 2013-02-16 18:23:06
At the moment (Revit 2013), room numbers and door numbers are not associated. Other similar associations have been requested, but don't exist yet, unfortunately. There might be some third party applications that help on this.
Planta1 Revit Online Consulting | info@planta1.com
Mon, Feb 18, 2013 at 11:00:48 AM | Door Marks linked to Room Numbers
JMBknvc
JMBknvc Avatar
trafoe5, thanks for the response, however I knew that all ready.
WW, thanks for the response and a good tip. However, it does not link the door and roon numbers. How have you been?
alfmedina, that was what I tought and need to send in for Wish List Item. Will look to see if there is a third party app.
Locking Door Marks
Fri, Aug 12, 2011 at 11:12:28 AM
Room tags, floor marks etc. misplaced in the mirrored plan
Wed, Aug 29, 2018 at 2:37:35 PM
room names not being picked up in door schedule
Mon, Apr 21, 2008 at 10:26:48 AM
Door schedule parameters not displaying "room names" from linked revit model.
Fri, May 15, 2015 at 1:22:11 PM
Schedule will not tracj all room names and numbers [ 1 2 ]
Fri, Jul 30, 2010 at 5:15:35 PM
16
Page generation time: 0.9802
