Forums >> Community >> Newbies >> Can not get Vertical siding on ground floor and horizontal on second floor?
Thu, Feb 14, 2013 at 9:04:35 PM | Can not get Vertical siding on ground floor and horizontal on second floor?
parkhurst35
When I change the the surface pattern to vertical for one wall it then changes the surface pattern to vertical on any other wall that is set with siding/clapboard. Why is this?
Fri, Feb 15, 2013 at 3:31:21 AM | Can not get Vertical siding on ground floor and horizontal on second floor?
4 Stars: 205 Votes
Because it's a TYPE parameter (check your HELP for "Instance / Type" parameters).
To avoid that, you have 2 options:
1) - use MODEL patterns, in this way you can ROTATE your pattern in an elevation view (only in that wall)
2) - select the wall and in your "Properties" tab goto "Edit", duplicate the wall and give another name, now you can Edit and rotate the pattern.
Sat, Feb 23, 2013 at 8:13:41 AM | Can not get Vertical siding on ground floor and horizontal on second floor?
parkhurst35
Thanks for the quick response, I got it figured out later that night.
Sat, Feb 23, 2013 at 8:16:34 AM | Can not get Vertical siding on ground floor and horizontal on second floor?
parkhurst35
Maybe you can help me with this other probllem, I have the front wall cladding higher than the second floor by about 4 ft. and the side wall makes an ugly join how to fix this? I have attached a pic.
Sat, Feb 23, 2013 at 8:23:11 AM | Can not get Vertical siding on ground floor and horizontal on second floor?
4 Stars: 205 Votes
TRIM the walls
Sat, Feb 23, 2013 at 9:02:07 AM | Can not get Vertical siding on ground floor and horizontal on second floor?
parkhurst35
Do you mean use a corner trim that will cover? Or by using the trim command?
Sat, Feb 23, 2013 at 9:56:05 AM | Can not get Vertical siding on ground floor and horizontal on second floor?
He meant - use the wall trim command.   But there are more problems here.
Revits wall trims don't work well with stacked walls or any walls that don't align the same wall type / thickness.  You may have to splt a wall horizontally to allow it to join differently at your junctions.
Sat, Feb 23, 2013 at 10:06:45 AM | Can not get Vertical siding on ground floor and horizontal on second floor?
parkhurst35
Ive done a stacked wall now on the second floor with horizontal on top and vertical on the bottom, how can I get the vertical siding lines to match up from first to second floor?
Sat, Feb 23, 2013 at 10:27:43 AM | Can not get Vertical siding on ground floor and horizontal on second floor?
4 Stars: 205 Votes
Use the "Align" tool
Sat, Feb 23, 2013 at 11:17:27 AM | Can not get Vertical siding on ground floor and horizontal on second floor?
parkhurst35
I've tried to to align the two edges, tried the center of top wall and profile edge line of bottom nothing changes. Could you elaborate on what to lines I should be aligning? I appreciate all the help!
Sun, Feb 24, 2013 at 5:42:55 AM | Can not get Vertical siding on ground floor and horizontal on second floor?
#11
4 Stars: 205 Votes
You have to align the PATTERN lines and not the wall, use the TAB key to help you.
First floor slab or ground floor ceiling?
Fri, Aug 30, 2013 at 7:41:03 AM
Window from floor above showing on ground floor plan
Mon, Oct 10, 2016 at 7:13:10 AM
Ground Floor info. appearing on Second Floor
Thu, Jun 9, 2016 at 2:24:40 PM
Faint lines showing from ground floor on first floor
Sat, Mar 10, 2012 at 4:40:33 PM
PFC + horizontal plate beam
Fri, Nov 5, 2010 at 12:08:52 AM
Page generation time: 0.5930
