Forums >> Revit Building >> Technical Support >> laptop not accessing central file to create a local
Thu, Feb 14, 2013 at 12:13:28 PM | laptop not accessing central file to create a local
Ptrdckrsn
Ptrdckrsn Avatar
1 Stars: 1 Votes
We have an issue with our laptop which is running on a home use lic. i can start a new project that that is not shared or open a project that is not shared. but it will ot open a local file of the central file. any is it a home use lic problem? any thoughts would be great, ver. 2011
Thu, Feb 14, 2013 at 12:27:18 PM | laptop not accessing central file to create a local
This is all covered in your help.  Searching for "remote" you find:  http://wikihelp.autodesk.com/Revit/enu/2012/Help/Revit_User's_Guide/2214-Collabor2214/2269-Working_2269/2290-Working_2290/2331-Working_2331
How to use a laptop offiste with a central file using worksharing?
Thu, Jun 27, 2013 at 12:09:29 PM
Accessing Central File Issues
Fri, Sep 28, 2012 at 7:12:14 AM
12
Can not create local file from Central
Tue, Mar 6, 2012 at 11:57:26 AM
" an unknown error occurred while accessing ....central.rvt"
Wed, Oct 11, 2017 at 12:53:21 AM
Revit Local File, Central Could Not Be Found
Mon, Feb 9, 2015 at 2:36:20 PM
Page generation time: 2.8020
