13 Users Online (11 Members):
Forums >> Revit Building >> Technical Support >> Problem with staris
31 Posts No Rating |
Hi, i want to create an U-shaped stairs with no gap (as in the picture).
I create one boundry line between the 2 flows but Revit "Couldn't generate surfaces for stairs."
I know that this is probably stupid qestion but any help will be apreciated.
Hope this help: http://wikihelp.autodesk.com/Revit/enu/2013/Help/00001-Revit_He0/0328-Build_th328/0330-Architec330/0505-Stair_by505
It didn't but thank you anyway.
I guess I shouldnt rely on forums, but try to learn Revit myself.
Edited on: Thu, Feb 14, 2013 at 5:27:56 AM
Made it by accident.
First I made the stairs with the Run option. Then I overlaped the middle two boudaries. And error apeared but at the end the stairs appeared right.
Thats the only way I can do it so far.
Thanks for the link Typhoon.
Edited on: Thu, Feb 14, 2013 at 6:50:45 AM
I believe you are working in 2012 right? The link I gave you is from 2013 where you can create that "By Component" wich is more "simple" and you have some videos about that.
In 2012 you can't overlap the boundary lines (well, not true but you'll have that "error" Warning in this case about the overlaping) BUT to avoid that follow the steps:
1) create the "run" sketch of your stairs (image 1)
2) delete the boundarie lines (image 2)
3) move the stair from the endpoint to the endpoint (image 3)
and done... no "error" or warning.
Edited on: Fri, Feb 15, 2013 at 5:16:14 AM
Thanks a lot!!! Problem solved.
ERROR MESSAGE: STAIRS - rises not intersecting boundries? |
Tue, Aug 19, 2008 at 7:15:25 AM
Lighting fixtures at different heights |
Wed, Jul 8, 2015 at 12:14:33 PM
walkthough elevations |
Sat, Mar 25, 2006 at 10:05:49 AM
STAIRS |
Mon, Jul 23, 2007 at 9:18:23 AM
Basic problem |
Tue, Feb 26, 2013 at 7:29:28 AM
