Forums >> Revit Building >> Technical Support >> How to Break up a Large Project.
Thu, Feb 14, 2013 at 12:42:06 AM | How to Break up a Large Project.
Beaucoupnice
Beaucoupnice Avatar
3.5 Stars: 6 Votes
Hi Everyone,
Just want to start by saying thankyou for all the great help over the years and the vast library of familys you make available to the world.
I'm about to start a huge project and I need advice how to break it into smaller manageable Revit Models.
The project is to be two high rise towers.
The first will be about 14 floors and about 20,000m2 (220,000 sq feet)
The second will be about 18 floors and be about 40,000 m2 (430,000 sq feet)
They will both be on the same site.
I was thinking of breaking the first one into 2 models with each dealing with an equal amount of floors.
I was thinking of breaking the second one into 3 models with each dealing with an equal amount of floors.
or maybe have the outer building envelope as one model and break up the inside equally.
It is a bit of a tricky one for me and I would value any assistance or advice based on experience anyone can offer.
Thanks
V
Thu, Feb 14, 2013 at 1:11:30 PM | How to Break up a Large Project.
alabaster2513
alabaster2513 Avatar
3.5 Stars: 25 Votes
are you using pretty advanced hardware?
Thu, Feb 14, 2013 at 1:27:17 PM | How to Break up a Large Project.
I'm not sure why you would want to break it up.  Two models, one for each building - yes, but beyond that?
The number of floors has nothing to do with this unless every floor is different.  And even then it may have little effect.
More information!
Thu, Feb 14, 2013 at 9:45:49 PM | How to Break up a Large Project.
Beaucoupnice
Beaucoupnice Avatar
3.5 Stars: 6 Votes
Hi,
Current Specifications are as follows
Intel(R) Xeon(R) CPU  W3520  @  2.67GHz   2.66GHz
8.00 GB RAM
NVIDIA Quadro FX 1800.
Based on what I have heard, I tend to limit the Revit model size to 250MB. Is this still stand as a correct approach?
Floors will be repetitive throughout.
Cheers
B
Fri, Feb 15, 2013 at 7:49:29 AM | How to Break up a Large Project.
If the floors are typical, you should not have a huge file size unless:
  • You import a lot of CAD "crap"  << Always BAD
  • You save a lot of rendered images in the project  << You don't need to save any!
  • You don't regularly clean your file
  • You have MEP in the same file << Always best to be separate and linked in
BTW - Using worksets and limited loads in really large files can help.  (A good paper on this: http://aucache.autodesk.com/au2011/sessions/5060/class_handouts/v1_MP5060_Rivera.pdf
I have not seen anything on the maximum file size for your sized system but 250 sounds way too small.   We did 250- on a 4 gig 32 bit system.
Fri, Feb 15, 2013 at 10:58:44 AM | How to Break up a Large Project.
alabaster2513
3.5 Stars: 25 Votes
I agree with WWHub completely. I do casino/hotel jobs and my tenant spaces are usually larger than 250mb. I love using the uniformat building codes to create my worksets. that give me options for placing my consultants work and all the different categories i need. then i would typically break them up by zones and tenants when it comes to ID and what not. I've definitely found there is no one size fits all solution to this and every project is unique. Starting with a nice core and shell base and evolving has been how it works for me. when the files get huge you just close the worksets you dont need for the task at hand.
Better to link or just use worksets for a large project?
Wed, Sep 22, 2010 at 10:31:56 AM
Need to break plan into two large plans.
Wed, Sep 16, 2015 at 10:57:50 AM
Combining Room Schedules and Area Schedules into one Large Schedule
Thu, Jan 3, 2013 at 10:57:33 AM
Showing break lines with Ramps and Stairs
Mon, Jul 30, 2018 at 11:02:36 AM
Break Line & Weld sybol families
Wed, Apr 28, 2010 at 9:18:41 PM
Page generation time: 0.5071
