Forums >> Revit Building >> Technical Support >> Rotating the project
Wed, Jan 25, 2006 at 9:01:48 AM | Rotating the project
jyothi
Hi, I am working on residential projects,we have option of right side garage and left side garage.i have built model of right side garage and done with construction documents etc. The left side garge model is exactly mirror of the right.so I require model and sheets to be mirrored for construction purposes. When i mirrored entire model by grouping them it is giving me error .how do i go about doing this. Is there any other method where i can produce mirrored sheets without cretating model again. Help me regarding this. Thanks,
Wed, Jan 25, 2006 at 9:37:58 AM | RE: Rotating the project
RevitRenzo
3.5 Stars: 3 Votes
Did you try linking it in another empty project and then rotate it.... You can try
Fri, Jan 27, 2006 at 12:45:29 AM | RE: Rotating the project
jyothi
Hi, Ya i did try with linking it in another empty project and then rotate.it is giving me error message,it says some of the base sketch is invalid for floors,ceiling,roof etc. i even tried grouping entire project and then placing it to other project and rotate din't help. Any other suggestions or workarounds? Thanks
Fri, Jan 27, 2006 at 2:38:19 AM | RE: Rotating the project
eldados
eldados Avatar
4.5 Stars: 8 Votes
link it into your site project (or what ever project) and mirror your linked model, not rotate...
Integrator
KarelCAD
Sat, Jan 28, 2006 at 3:42:47 AM | RE: Rotating the project
jyothi
hi, eldados Sorry if i am wrong,i think if we link the project only model will be existing.But i dont want only the model to be rotated or mirrored. i require entire construction document,details sheets to be reproduced, as with the original project.I have to produce sheets which is mirrored,since like in autocad we cannot mirror sheets in revit.I have made the copy of the original project and wanted to rotate or mirror the entire project so i will get my sheets mirrored Did i confuse?. is there a way? Thanks,
Sat, Jan 28, 2006 at 12:11:46 PM | RE:
Scott Davis
3.5 Stars: 3 Votes
hi,
eldados
Did i confuse?.
is there a way?
Thanks,
Contact Revit support, they will be able to help you with your mirroring problems.
Mon, Feb 6, 2006 at 1:23:19 AM | RE: Rotating the project
hippy
I actually had to mirro an entire 3 story condo. I never got everything to work and had to do a little redrawing before it was over but by working with the filters and a few piece at a time unlocking diminsions and alignments I think I got everything to mirror except my created in place generic modols (window trim and opening sweeps). It tokk me quite a while.
Mon, Feb 6, 2006 at 7:13:12 AM | RE: Rotating the project
jyothi
Thaks hippy, i was able to handle this i also did the sam ething i useed filter ,unconstrained some of the constrained objects and it worked out well. Thanks for your time Regards,
Mon, Feb 6, 2006 at 7:13:33 AM | RE: Rotating the project
jyothi
Thanks hippy, i was able to handle this i also did the same thing i used filter ,unconstrained some of the constrained objects and it worked out well. Thanks for your time Regards,
Rotate Floor Plan without rotating project
Mon, Nov 4, 2013 at 1:14:56 PM
Rotating a Project
Thu, Jun 29, 2006 at 9:08:00 AM
How to Rotate True North without rotating the whole Project?
Thu, Mar 18, 2010 at 7:25:35 PM
Rotating Symbol geometry without rotating leabel
Wed, May 6, 2009 at 8:33:58 AM
Rotating views to project north
Mon, May 28, 2007 at 3:46:10 PM
Page generation time: 2.9010
