Forums >> Community >> The Studio >> rotating in Y axis?
Wed, Feb 13, 2013 at 8:18:04 AM | rotating in Y axis?
ehsanshp
Hi friends
How can I rotate a wall that I have made using wall component in Y axis?
I mean it is easy to rotate it in X axis but i like to make it vertically crooked
Thanks
Wed, Feb 13, 2013 at 8:32:36 AM | rotating in Y axis?
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
You can't rotate a wall in the "y" direction however I believe you mean Z.  You can go to an elevation view and edit your profile, or create a reference plane for your wall to sit on.  I'm not exactly sure what you are trying to accomplish
Wed, Feb 13, 2013 at 3:03:27 PM | rotating in Y axis?
ehsanshp
Thanks for replying
Yes I mean Z axis Smile
I have made a wall using made in place in component category and used extrusion with some patterns on it in X-Z plane (elevation) and now I need to rotate it in Y-Z plane to make it a little lopsided but revit messaged "Can't rotate element into this position"
Is there any way to do it in revit or can I exported in another software and do this and then continue working on it in revit?
Thanks
Wed, Feb 13, 2013 at 3:22:11 PM | rotating in Y axis?
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
To do what you are looking for you will need to do an in-place MASS and then apply wall by face.
Wed, Feb 13, 2013 at 3:30:01 PM | rotating in Y axis?
If it is an extrusion, then modify it and make it be a blend.  << Better solution because top and bottom will still be flat in plan.
Rotating mullions
Thu, Jul 24, 2008 at 4:27:53 PM
Rotating Items on X-axis
Wed, May 25, 2011 at 12:56:39 PM
objects move in Y-axis but not X-axis
Wed, Nov 2, 2005 at 11:04:31 PM
Axis in elevation is funky
Wed, Mar 25, 2009 at 1:07:48 PM
Rotating Family Geometry around XYZ axis's
Sat, Feb 20, 2016 at 5:43:14 PM
Page generation time: 0.1967
