Forums >> Revit Building >> Technical Support >> Family Template Types
Wed, Feb 13, 2013 at 6:25:23 AM | Family Template Types
FITZT70
I am trying to get my head around families, and I would like a clear understanding of the various template types that are available with Revit.  Some of them I understand readily like floor, and ceiling based templates but others I'm not so sure.  For example:
RPC Family.rft
Generic Model Pattern based.rft
I've been reading lots of books that caution about making families dependent on hosts that may not be visible for consultants but I have not found a spread sheet or simple explanation that shows how all these templates vary, what they are useful for and what settings they are intended.  Does anyone know of a link to some place that explains each type and gives some pros and cons for each?
Wed, Feb 13, 2013 at 7:19:25 AM | Family Template Types
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Have you read Revits Family Guide?
http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=13376394
Wed, Feb 13, 2013 at 7:19:44 AM | Family Template Types
Your REVIT HELP is one of the best resources you have - learn to use it.  Under families, you will find this:
http://wikihelp.autodesk.com/Revit/enu/2012/Help/Revit_User's_Guide/0325-Build_th325/1279-Revit_Fa1279/1280-Families1280/1284-The_Fami1284
I strogly suggest you download the families guide that is pointed to there.
Edited on: Wed, Feb 13, 2013 at 7:20:16 AM
Family types - conditional statement
Mon, Apr 18, 2011 at 3:59:50 PM
Project Template / Wall Types / Families
Tue, Oct 8, 2013 at 9:30:07 AM
Door and Window types
Thu, Nov 23, 2017 at 11:19:52 AM
Purge Command - possible to purge family types accidentally?
Tue, Aug 20, 2013 at 12:01:08 PM
Family types problem.
Tue, Apr 21, 2009 at 10:00:20 AM
Page generation time: 1.9204
