Forums >> Revit Building >> Technical Support >> Problem with grouping
Wed, Feb 13, 2013 at 4:28:58 AM | Problem with grouping
leedeetee
Hi,
Can anyone shed any light on the following problem, please?
I've created an external staircase that we use here, and It all looks/works pretty much how I want it.
However, when I try to group the staircase, the selection box seems to encompassing an erroneous point when views in a plan view??? I've tried modeling the the railing again ,Puged Unused, creating a new group but, nothing seems to work. It seems fine in 3d views, though.
Any ideas?
I've attached the problematic file for reference.
Many thanks.
Edited on: Wed, Feb 13, 2013 at 4:31:31 AM
Edited on: Wed, Feb 13, 2013 at 4:35:08 AM
Wed, Feb 13, 2013 at 5:50:53 AM | Problem with grouping
Why are you grouping and what?
Remember, stairs are tied to levels and as such are not as "transportable" between projects.
Wed, Feb 13, 2013 at 6:05:11 AM | Problem with grouping
leedeetee
Hi WW,
I'm grouping the railings with stairs, landing and columns etc.
All our projects have standard levels as we deal exclusively in modular buildings.
Thanks.
Thu, Feb 14, 2013 at 2:49:18 AM | Problem with grouping
leedeetee
I've just discovered that the reason the bounding box of the group is so large is that the group contains the project base point.
Is there any way I can exclude this from the group?
Many thanks.
Thu, Feb 14, 2013 at 1:50:03 PM | Problem with grouping
I have never seen this in a group but it may be that by including the stairs that demanded levels, this was also included.  Just a guess.
Grouping Line-based Families
Mon, Oct 30, 2006 at 12:00:45 PM
Grouping Floors
Mon, Aug 22, 2005 at 3:47:49 PM
Graphical Column Schedule - Not Grouping all similar instances
Wed, Nov 5, 2008 at 11:11:18 AM
Schedules - Grouping by Unit
Tue, Nov 21, 2006 at 5:51:55 PM
Grouping issue
Mon, Dec 19, 2016 at 12:12:45 PM
Page generation time: 1.7070
