10 Users Online (8 Members):
Forums >> Revit Building >> Technical Support >> attachig walls to circular stairs
9 Posts No Rating |
I am tyring to model an entry stair system with circular stairs that has an attached wall below. The only way I seem to be able to create a wall below the stairs close to the shape of the bottom side of the stairs is by creating a reference plane and attaching the wall to the reference plane. The only problem with it is that the only way I know to make the ref. plane for this is straight on in elevation, so the walls do not perfectly mimic the shape of the stairs because the reference plane is flat and the stairs are not.
Is there an easy way or any way to do this?
using Revit 2012
gday bonchaws,
see link below, bruce gows blog
http://revit-alize.blogspot.com.au/2006/04/below-stairs.html
hope this helps
cheers
geoff
This is an old question... Similar threads, bottom of this page!
circular stairs |
Mon, Mar 24, 2008 at 4:40:37 PM
Circular Stairs |
Thu, Nov 3, 2005 at 5:13:20 PM
circular stairs with spiraling wall around them |
Tue, Mar 24, 2009 at 3:58:27 PM
circular stairs |
Wed, Mar 16, 2005 at 10:02:03 AM
Attaching Rails to walls |
Thu, Aug 13, 2009 at 12:59:42 PM
