Forums >> Revit Building >> Technical Support >> Skirtings - scheduling
Tue, Feb 12, 2013 at 11:36:07 AM | Skirtings - scheduling
MrSchumi
Is it possible to schedule/quantify wall skirtings when they are created as 'in-place' sweeps?
Thanks in advance!
Tue, Feb 12, 2013 at 12:16:21 PM | Skirtings - scheduling
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
If you make your sweeps using in-place families you can schedule them.
Tue, Feb 12, 2013 at 12:18:25 PM | Skirtings - scheduling
Did you look under schedules?  Your question suggests you did not because you can schedule wall sweeps.
Tue, Feb 12, 2013 at 10:35:31 PM | Skirtings - scheduling
Pavan
Pavan Avatar
4.5 Stars: 3 Votes
Create In-Place family in 'Generic Model' category.
Using Material Take off you can generate  schedule/quantities.
Pavan Reddy
Revit Manager
Intelligence is not always knowing the answers, it's always asking the questions.
Wed, Feb 13, 2013 at 7:16:44 AM | Skirtings - scheduling
MrSchumi
I'm using Revit 2013, and creating the skitings by sketching the path. I've tried categorising the skirting under various categories including 'generic models', but when I create a Material Take Off or Scehdule/Quantities, no quantities are generated under any of the fields - and the most important field I require i.e. 'length' is not available. Am I doing something wrong?
Wed, Feb 13, 2013 at 10:27:52 PM | Skirtings - scheduling
Pavan
Pavan Avatar
4.5 Stars: 3 Votes
Have you assigned any material to your In-place skirting family???
Check the attached model for more details.
Pavan Reddy
Revit Manager
Thu, Feb 14, 2013 at 7:10:53 AM | Skirtings - scheduling
MrSchumi
Thanks guys have it working now!
Fri, Oct 5, 2018 at 1:31:45 AM | Skirtings - scheduling
daait
only material and length
base trim
Thu, May 25, 2006 at 5:12:12 PM
Retaining Curtain Wall Door Scheduling Data
Thu, Jan 8, 2015 at 2:47:08 PM
Wall Scheduling
Mon, Sep 10, 2018 at 8:06:43 AM
SCHEDULING CONDUIT BENDS
Thu, Sep 21, 2017 at 10:06:06 AM
Calculation for Text in Scheduling
Mon, May 30, 2016 at 8:02:21 AM
Page generation time: 0.0406
