Forums >> Revit Building >> Technical Support >> Sweeps Not Joining
Tue, Feb 12, 2013 at 9:17:12 AM | Sweeps Not Joining
amok
Hello there,
 Again I’m not the greatest Revit modeller so please bear with me. I'm using revit 2013.
 I have to join to walls chamfers under a slab that I have created using a sweep. They will join each other if they are the same wall type. However they are two different wall types. I believe the dimensions for the chamfer are the same. Please see the attached images for a proper description.
Is this the best way to model these feature or is there a more sensible way to do it?
Cheers and thanks for any help!!
Tue, Feb 12, 2013 at 9:23:20 AM | Sweeps Not Joining
Use a slab edge instead of a wall sweep.
Tue, Feb 12, 2013 at 9:48:45 AM | Sweeps Not Joining
4 Stars: 205 Votes
I don't know how you are doing that sweep because Sweeps use a PATH and tthat path can be a "CLOSED LOOP", in this way, you'll have a PERFECT sweep BUT like WWhub told you use a "SLAD EDGE"
Wed, Feb 13, 2013 at 10:54:51 AM | Sweeps Not Joining
amok
Hi WWhub and Typhoon,
Great stuff that worked thanks. However in some of my views the chamfer appears but in other it does not. Where are the slab edges in the visibility/graphic overrides so that I can add them to my view templates?
Again thanks for sorting this one out.
Wed, Feb 13, 2013 at 10:58:02 AM | Sweeps Not Joining
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Slab Edges are a subcategory of the Floor Category.
Thu, Feb 14, 2013 at 1:51:52 AM | Sweeps Not Joining
amok
HI dgcad,
I’m still having trouble getting the chamfer of the slab edge to appear. I’ve attached a stripped down revit file. If you could have a look at it I would greatly appreciate it (my deadline is tomorrow!?!?!?).
Briefly, in the coordination view the chamfer appears but not in the structural view, which is the one I need it to be on in. The slab edge category appears to be on in the V/G Model Overides in the template.
If you can help that will be great thanks
Amok
Thu, Feb 14, 2013 at 1:47:40 PM | Sweeps Not Joining
No file....
Mon, Feb 18, 2013 at 10:14:24 AM | Sweeps Not Joining
amok
Hello there, I figured out the problem on Friday. I used the show hidden line function in the view tab to show the hidden line work (sound obvious now!). It works a treat.
Thanks for all yor assistance WWHub and Typhoon
Cheers Amok
Parapet wall sweeps not joining
Fri, Oct 25, 2013 at 3:00:32 PM
Roof Joining Issue
Mon, Jan 21, 2013 at 7:54:18 PM
12
Problem connecting wall sweeps (horizontal and vertical)
Fri, May 4, 2012 at 2:07:26 PM
Angling Wall Sweeps
Mon, Aug 15, 2011 at 1:26:41 PM
highrise towers slabs-walls joining
Tue, Jun 1, 2004 at 6:18:09 PM
Page generation time: 0.1235
