Forums >> Revit Building >> Technical Support >> rendering problem
Mon, Feb 11, 2013 at 11:14:02 AM | rendering problem
bwoods0713
I took the camera shot from inside my building and the points are still inside the building, but when I render it the render image is from outside the building. I've asked many people and no one had an answer for me as to why this is happening. Any ideas? Attached are the image to be rendered and how it came out.
Edit- ok so the image to be rendered won't show up but it is from inside the building
Edited on: Mon, Feb 11, 2013 at 11:15:58 AM
Edited on: Mon, Feb 11, 2013 at 11:17:13 AM
Mon, Feb 11, 2013 at 11:46:55 AM | rendering problem
j0ker007
looks like you are rendering a elevation?
are you sure your not going into the 3D views pull down and picking the "3D view 1" or etc then going to "show render
dialog"?
also to you might want to select the crop window of your 3D view and then switch back to a floor plan.  that will show you
where the camera and camera cone is located.  hope this helps
Mon, Feb 11, 2013 at 12:15:04 PM | rendering problem
bwoods0713
Yea I had already checked all of that because I was thinkin the same thing, I tried all the other possible options and still get the same thing. I even have moved the camera and still get the same rendered image. Now it won't even render half of the time. I'm rendering through autodesk 360 just like I did the others.
Edited on: Mon, Feb 11, 2013 at 12:16:48 PM
Revit 2009 Rendering Problem(Black screen) [ 1 2 ]
Mon, Apr 1, 2013 at 2:45:28 PM
27
Rendering Problem
Wed, Feb 6, 2013 at 1:41:48 PM
Problem while rendering
Tue, Feb 12, 2013 at 1:37:23 AM
rendering
Thu, Jan 26, 2012 at 11:54:10 AM
rendering problem with windows
Fri, Jan 13, 2012 at 3:31:28 PM
Page generation time: 0.7597
