Forums >> Revit Building >> Technical Support >> Stepped Plans??
Mon, Feb 11, 2013 at 8:05:02 AM | Stepped Plans??
amok
Hello there,
I'm fairly new to this Revit so please bear with me if its obvious!! I use Revit 2013 and have the following question:
I have a site that falls in level and the proposed floor levels roughly follow this fall. However when I cut a plan through the floors they are picking up part of the floor levels above (Because of the fall in site) and the plan I want to create is underneath it. Please see the attached image as it’s pretty hard to describe! The red line indicates roughly what the desired plan line should look like.
Has anyone got any solutions/ideas about how I can get around it? It will be greatly appreciated.
Cheers
Mon, Feb 11, 2013 at 8:17:08 AM | Stepped Plans??
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
You can use a Plan Region over the stepped area to get a separate view range for the 2 areas.
Mon, Feb 11, 2013 at 9:11:09 AM | Stepped Plans??
amok
Cheers teafoe5 it has worked!
Stepped Roof with Overhand
Fri, Oct 25, 2013 at 10:40:43 AM
How to Create Stepped Footings
Wed, Mar 25, 2015 at 12:30:37 PM
Stepped Ceiling
Wed, Dec 3, 2008 at 6:46:48 PM
Stepped Footing CADclip Tutorial
Wed, Feb 10, 2010 at 3:37:09 PM
Stepped Foundations walls dont show in view?
Fri, Jan 9, 2015 at 7:52:24 AM
11
Page generation time: 0.6396
