Forums >> Revit Building >> Technical Support >> using revolve tool to shape top of walls 'Revit 2012'
Sun, Feb 10, 2013 at 8:25:13 PM | using revolve tool to shape top of walls 'Revit 2012'
bonchaws
Just trying to shape top of walls using the revolve tool.
When I try and cut the revolve from the wall, It will only allow me to select either the revolve or the wall. It will not let me select the object I want to cut from.
This is what I am doing.
Step 1. select componet> model in place.
sep 2. select category fo walls and name the family 'wall void revolve.'
step 3. on plan view I create  a reference plane. and name the plane  Wall void revolve
Step 4. go to elevation and model the revolve. ( void) I set the reference plane to the Wall void revolve.
Step 5.finish the revolve and then use the cut tool to remove the top of the walls from the revolve.
This is where it wont work. I click on the revolve and than It will not let me click on the walls. or if I click on the walls first, it will not let me click on the revolve.
I have only used the revolve in Auto Cad and never using this Revit. Please help me if you can.
Thanks
B. Chaws.
Mon, Feb 11, 2013 at 3:47:26 AM | using revolve tool to shape top of walls 'Revit 2012'
4 Stars: 205 Votes
You are doing something wrong... create the void then click on "CUT geometry" tool, in the "OPTION bar" you'll see "Multiple cut", turn on that, now select the VOID (once) then select the walls (one by one).
Wed, Feb 20, 2013 at 1:59:08 PM | using revolve tool to shape top of walls 'Revit 2012'
senorfranco
Did you ever figure out the issue? I am having the same struggle... I don't know what step I am doing wrong. Please help.
Wed, Feb 20, 2013 at 2:47:55 PM | using revolve tool to shape top of walls 'Revit 2012'
senorfranco
I just figured it out: the identity data of the solid/void was set to solid rather than void. I switched to void and voila, I was able to cute the void from the walls.
shapeing top of walls with void revolve
Tue, Feb 12, 2013 at 4:01:01 AM
''Visibility grafics'' and ''create parts'' problem when mak
Fri, Mar 19, 2021 at 11:45:46 AM
Error 'top of wall is lower than base of wall'
Mon, Sep 2, 2013 at 3:24:43 PM
Create form tool for components other than mass - Revit Architecture 2012
Mon, Oct 20, 2014 at 4:15:58 PM
Curtain panel - ''wont make type'' - Please help
Tue, Apr 23, 2013 at 8:10:58 AM
Page generation time: 3.8588
