Forums >> Revit Building >> Technical Support >> Problem while rendering
Sat, Feb 9, 2013 at 6:23:19 AM | Problem while rendering
Suresh1622
I cant get the optput wall colour true RGP.......... Whats the problem?
See the image;;;;
First one i set the RGP like that....
Second one i get the output after rendering like that....
any suggestion?////////
Mon, Feb 11, 2013 at 10:48:50 AM | Problem while rendering
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
You need to be more clear. I can't understand what you are trying to do. It appears you are trying to get purple and purple is what you are getting.
Also what are you trying to render exactly and what type of view are you in ?
Mon, Feb 11, 2013 at 11:03:49 AM | Problem while rendering
At this point in time, there is no way to assure that the color on your screen and the color on a print will match each other or a true color scale.
Mon, Feb 11, 2013 at 11:43:45 AM | Problem while rendering
j0ker007
Well I think you mean "RGB" instead of RGP?
I think you need a little info
RGB - Red, Green, and blue for the pixels on your montor.
When you want to print it comes out if its a normal off the shelf print CMYK.
Nice since you rendering something it also depends on your lighting in your scene.  is it
exterior lighing and / or artifical lighting?
also which verison of Revit are you using??
Mon, Feb 11, 2013 at 4:12:18 PM | Problem while rendering
alabaster2513
alabaster2513 Avatar
3.5 Stars: 25 Votes
looks over saturated, try stepping down to .9 post render. altho that will affect other colors as well. by default revit tends to under saturate colors which is odd that yours is not doing that
Tue, Feb 12, 2013 at 1:34:32 AM | Problem while rendering
Suresh1622
Thank u for ur various answers....
But i would like to get the output wall color in purpule but i cant....
If i set the colour in purpule,but the output came like megentha after rendering.........
what is the reason?
Tue, Feb 12, 2013 at 1:37:23 AM | Problem while rendering
Suresh1622
I understood about the RGP........
First of all i have to apply the wall colour depend upon the RGP..........
I am using REVIT2011 Mr j0ker007
Revit 2009 Rendering Problem(Black screen) [ 1 2 ]
Mon, Apr 1, 2013 at 2:45:28 PM
27
Rendering Problem
Wed, Feb 6, 2013 at 1:41:48 PM
rendering
Thu, Jan 26, 2012 at 11:54:10 AM
rendering problem with windows
Fri, Jan 13, 2012 at 3:31:28 PM
problem rendering in 2010
Sat, Apr 24, 2010 at 2:38:51 PM
Page generation time: 5.4693
