Forums >> Revit Building >> Technical Support >> AutoCAD .pat into Revit 2013
Fri, Feb 8, 2013 at 3:19:12 PM | AutoCAD .pat into Revit 2013
winterriver
So this is the .pat file for a 1 hour wall. Any ideas on how to add text into this so my wall fill pattern reads
-0-0-0-0-0- or -51-51-51-
*1 Hour, 1 Hour;%TYPE=DRAFTING0, 0.015275,4.06714, 0.34375,4.06734, 0.0003,-0.343450, 0.015275,4.06754, 0.34375,4.06734, 0.0003,-0.343450, 0.015375,4.06724, 0.34375,4.06734, 0.0001,-0.343650, 0.015375,4.06744, 0.34375,4.06734, 0.0001,-0.343650, 0.015675,4.06714, 0.34375,4.06734, 0.0003,-0.343450, 0.015675,4.06754, 0.34375,4.06734, 0.0003,-0.343450, 0.015875,4.06734, 0.34375,4.06734, 0.0001,-0.34365
Mon, Feb 11, 2013 at 7:25:57 AM | AutoCAD .pat into Revit 2013
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
I don't believe that is possible.
Mon, Feb 11, 2013 at 7:39:04 AM | AutoCAD .pat into Revit 2013
winterriver,
Your question was answered last week and Typhoon gave you the solution.
Mon, Feb 11, 2013 at 9:27:43 AM | AutoCAD .pat into Revit 2013
winterriver
thank you wwhub. Edited on: Mon, Feb 11, 2013 at 9:44:09 AM
Edited on: Mon, Feb 11, 2013 at 9:45:03 AM
New pat pattern help
Tue, Nov 1, 2011 at 8:26:43 AM
Exporting from Revit 2013 to Autocad MEP 2010 while retaining intelligent object
Sat, Dec 7, 2013 at 12:08:38 AM
Use Pat Files
Tue, Sep 1, 2009 at 4:18:40 AM
11
Pattern (.PAT) Files
Mon, May 3, 2021 at 4:51:04 PM
Need help with a PAT file
Thu, Sep 29, 2011 at 12:55:36 PM
Page generation time: 4.4517
