Forums >> General Discussion >> Revit Project Management >> Walls
Fri, Feb 8, 2013 at 10:11:42 AM | Walls
EBrandon123
Could you please advise on the best way to work with external walls where the internal finish varies.
For example if you have a cavity wall build up with the internal face being plasterboard on block work. How do you deal with a room where you don't want a plasterboard finish, instead you may just want to paint the block work. Is it better to draw the internal plasterboard finish on all walls as a separate wall and joining geometry rather than making it part of the cavity wall system?
Fri, Feb 8, 2013 at 11:05:32 AM | Walls
You can do a thin wall as you suggested or you could have seperate exterior cavity walls with/without the interior finish.
Mon, Feb 11, 2013 at 10:20:34 AM | Walls
andy777bennett
also is the split face option. just draw an elevation in the room and when done drawing split face, paint it what you want it to look like.
Attaching Rails to walls
Thu, Aug 13, 2009 at 12:59:42 PM
Walls
Thu, Dec 16, 2004 at 4:56:57 PM
solid walls transparent to curtain walls and railings in back..
Mon, Oct 29, 2012 at 7:34:26 AM
Foundation walls & Normal walls joint, linework tool?
Sun, Nov 1, 2009 at 12:24:18 AM
Inner walls overslaping outer walls.
Sun, Dec 14, 2014 at 4:58:35 PM
Page generation time: 5.2234
