Forums >> Revit Building >> Technical Support >> All Imported Cad lines have turned Black
Fri, Feb 8, 2013 at 9:19:47 AM | All Imported Cad lines have turned Black
JRPcad
For some reason at some point I'm guessing I must have accidentally hit on some kind of shortcut that has turned all of my imported Cad Lines to black from the colour that was originally preserved. I've checked in object styles and they still have their colours per layer listed so seems fine, yet visually they are all now Black. Is there a setting somewhere that lets me bring back the colour as I need to trace some beams over the beams layer but can't for the life of me work out where they all are and the extents they go to. I could turn off all of the other but it's still hard to see where they are as the black blends in with the rest of my model.
I need my colour back please help Winking
For Architectural Services visit www.jrpcad.co.uk
Fri, Feb 8, 2013 at 9:37:21 AM | All Imported Cad lines have turned Black
JRPcad
Just to add, I've realised it is view specific, only my GF view is in black and white, the others still show the import as coulour, I've even tried re importing it and no luck.
So there is a setting somewhere causing this in that particular view, please help someone Crying
Fri, Feb 8, 2013 at 10:20:37 AM | All Imported Cad lines have turned Black
JRPcad
Never Mind I think it was just a glitch:
fr some reason if I changed my View template to something else and back to what it was all the colour comes back, so very strange???
would still like to know why it happened though?
Fri, Feb 8, 2013 at 12:11:03 PM | All Imported Cad lines have turned Black
It is in your view VG settings under imports.
Sat, Feb 9, 2013 at 2:42:53 AM | All Imported Cad lines have turned Black
JRPcad
Yeah that's the first place I checked and all was okay, I think it was a deffinate Bug I stumbled across somehow.
Thu, Sep 29, 2022 at 12:26:38 AM | All Imported Cad lines have turned Black
Hanshadow
Experienced the same, what I did is to make the imported dwg in the same level as the one you are working .
PINOY AKO!
Importing a CAD site plan w/ hatch
Tue, Aug 30, 2011 at 1:51:06 AM
Line Weights in Imported CAD drawing - Change weights but not scale?
Thu, May 17, 2012 at 2:02:02 PM
Imported CAD drawing lines not showing regenerated
Mon, Apr 27, 2009 at 4:25:18 PM
Imported Cad Lines not "live" [ 1 2 ]
Fri, Aug 15, 2008 at 2:02:40 PM
15
revit 2012 - display option background disappeared and turned black
Mon, Jun 25, 2012 at 4:48:13 PM
Page generation time: 2.0035
