Forums >> Revit Building >> Technical Support >> Foundation Plan & Basement Walls
Thu, Feb 7, 2013 at 12:34:24 PM | Foundation Plan & Basement Walls
jmkennedy
I'm sure this has been answered before but I couldn't find anything to address this with any kind of consistent answers in the forums.
Using Revit Architecture 2012.
I'm modeling a house with a walkout basement and am working on the foundation plans.  I had originally modeled the house with the basement wall with a concrete core of 8", then insulation, furring & drywall all as 1 wall.  Now that I am doing the foundation plan I only want to see the core (the concrete).  From what I can tell the only way to make this work is to use "create parts" and explode the wall basically.  I'd prefer not to bog down my model by doing this.
Should I have just modeled the concrete wall and the furred out portion of the wall separately?
What do you do?
Thanks!
Thu, Feb 7, 2013 at 1:07:45 PM | Foundation Plan & Basement Walls
You can do it your way (seperate walls, one agaist the other and joined)... we do that quite often.
Thu, Feb 7, 2013 at 3:52:14 PM | Foundation Plan & Basement Walls
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Yes I do it as two seperate walls. But like WW said make sure you 'join' them so when you put a window in it will penetrate both walls.
Also pay attention to the corner joins. They can be problematic.
Thu, Feb 7, 2013 at 4:09:33 PM | Foundation Plan & Basement Walls
coreed
coreed Avatar
4 Stars: 16 Votes
Do it as it would be built.
"modeled the concrete wall and the furred out portion of the wall separate"
Then join where needed.
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Basement Wall Function: "Foundation" or "Exterior"?
Fri, Mar 26, 2010 at 12:27:21 PM
Level 1 room boundries showing up in foundation level
Fri, Feb 15, 2008 at 9:31:36 AM
wall & categories
Wed, Jan 13, 2010 at 1:20:28 AM
Walls
Thu, Dec 16, 2004 at 4:56:57 PM
where are my walls??
Fri, Apr 3, 2009 at 2:46:26 PM
Page generation time: 0.6946
