Forums >> Revit Building >> Technical Support >> Area plan
Wed, Jan 25, 2006 at 5:48:02 AM | Area plan
jyothi
Hi, I am using desgin option.And i am unable to figure out how to create differnet area plan for same plan but different option.for example i have first floor plan with differnt entrance area,porch,living area for which i have used design option.But i am unable to create area plan for differnt option. i tried using visibility graphics but dint help. Any methods to create this? Thanks,
Wed, Jan 25, 2006 at 9:30:54 AM | RE: Area plan
RevitRenzo
3.5 Stars: 3 Votes
The method you have to do is the following assuming we have a Flloor plan, duplicate this View In the first Floor Plan go to the Visibility graphics and turn on option 1 (so change the Automatic setting into your option) In the duplicated Floor Plan go to the visibility graphics and turn on option 2 Now you can drag & drop both floor plans on one sheet
Fri, Jan 27, 2006 at 12:32:26 AM | RE: Area plan
jyothi
Hi, I duplicated the view and changed in the visilibity graphics to option 1 or option 2.I will get plan for that option but not the colour fill.How do i do that? Thanks,
Fri, Jan 27, 2006 at 2:44:51 AM | RE: Area plan
eldados
eldados Avatar
4.5 Stars: 8 Votes
you will need to create another colour , just name it something else, and use that colour for the other option...
Integrator
KarelCAD
Area Plan does not match Area from Materia/l Area
Tue, Feb 13, 2018 at 7:50:03 AM
Area from Area plan to show on floor plan
Fri, Feb 27, 2009 at 7:53:29 PM
Area Plan
Thu, Aug 7, 2008 at 11:58:56 PM
Disappearing Area Plan
Fri, Sep 4, 2009 at 12:01:37 PM
Use Area Plan as my Floor Plan?
Fri, Aug 30, 2019 at 12:31:02 PM
Page generation time: 2.4054
