Forums >> Revit Building >> Technical Support >> Inserting IFC into AutoCAD MEP
Thu, Feb 7, 2013 at 9:32:07 AM | Inserting IFC into AutoCAD MEP
ccook79
I have an ifc file from revit and need to insert this in to MEP. This is version 2011. Does anyone know the command to import this?ThanksChris
Tue, Feb 12, 2013 at 2:01:28 PM | Inserting IFC into AutoCAD MEP
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
I found this IFC Exported App that may help.  I have never used it so I do not know the capabilities.
http://apps.exchange.autodesk.com/RVT/Detail/Index?id=appstore.exchange.autodesk.com%3Aifcexporterforrevit%3Aen
http://whatrevitwants.blogspot.com/2012/04/ifc-exporters-and-importers-and-tips.html
importing IFC files in to MEP 2011
Mon, Feb 11, 2013 at 10:53:22 AM
Revit MEP or AutoCad MEP
Fri, Oct 14, 2011 at 8:21:49 AM
IFC Color Change?
Fri, Nov 9, 2007 at 10:46:21 AM
Revit MEP IFC Export - Objects not detalied
Wed, Jul 2, 2014 at 8:08:29 AM
Exporting from Revit 2013 to Autocad MEP 2010 while retaining intelligent object
Sat, Dec 7, 2013 at 12:08:38 AM
Page generation time: 0.9986
