Forums >> Revit Building >> Technical Support >> ADDING .PAT FILES TO MY LIBRARY
Tue, Jan 24, 2006 at 7:32:51 PM | ADDING .PAT FILES TO MY LIBRARY
JOHNRAUGUST
I have a bunch of .pat files I want to make into patterns. Where do I save them into? Then, how do I load them into my template file so they are always there? Any help would be appreciated!
Tue, Jan 24, 2006 at 7:36:38 PM | RE: ADDING .PAT FILES TO MY LIBRARY
arccodex1
3 Stars: 1 Votes
Goto Settings... Fill Patterns and import your PAT files at the proper scale. Then goto Settings... Materials and setup the Surface Patterns for each material. If you load them into your template they should be there for you each time you start a new project. Post edited on 2006-01-24 19:36:53
Pat Files
Thu, Jan 22, 2009 at 1:26:47 PM
looking for .pat files [ 1 2 ]
Tue, Dec 1, 2020 at 1:43:31 PM
24
Use Pat Files
Tue, Sep 1, 2009 at 4:18:40 AM
11
Is there a way to preview .pat files / hatch patterns in thumbnails in a folder?
Mon, Jul 6, 2015 at 11:01:26 AM
custom pat files
Fri, Oct 21, 2005 at 3:13:23 PM
Page generation time: 4.0937
