Forums >> Revit Building >> Technical Support >> Conditional Parameters
Thu, Feb 7, 2013 at 12:52:53 AM | Conditional Parameters
noddless
I'm formula iliterate. Anyone can help?
Scenario: To check if the result when Area divide D1, D2 and D3 equal to W1 and W2.
I created the formula
if(Area / D1 = (or(W1,W2)), "Yes", if(Area.D2=(or(W1,W2)), “Yes”, “No” ))
but always end up with  "Inconsistent units". Any other optionto achieve the same result?
Edited on: Thu, Feb 7, 2013 at 1:18:30 AM
Edited on: Thu, Feb 7, 2013 at 1:18:44 AM
Tue, Feb 12, 2013 at 8:46:16 PM | Conditional Parameters
alfmedina
alfmedina Avatar
4 Stars: 8 Votes
I recommend reading about formulas in Wikihelp, from this link:
http://wikihelp.autodesk.com/Revit/enu/2013/Help/00001-Revit_He0/2760-Tools_an2760/3001-Formulas3001/3005-Conditio3005
That will give you a good starting point about condional statements, embedded IF's, logical operators AND or OR, units, etc...
Planta1 Revit Online Consulting | info@planta1.com
Tue, Feb 12, 2013 at 9:13:52 PM | Conditional Parameters
noddless
i tried but it doesnt turn out well especially when I used the "OR" in "IF"
conditional formatting yes no parameters
Tue, Oct 28, 2008 at 9:58:54 AM
Conditional statement
Thu, Jun 27, 2013 at 9:58:47 AM
Conditional Parameters Setting In Revit
Tue, Jun 26, 2018 at 7:25:52 AM
Need help with Summing yes/no parameters
Fri, May 9, 2008 at 4:42:56 PM
Schedule Line Shading - Revit 2009
Fri, Oct 1, 2010 at 3:53:10 PM
Page generation time: 1.3253
