Forums >> Revit Building >> Technical Support >> Importing Point cloud into correct position
Wed, Feb 6, 2013 at 5:14:19 AM | Importing Point cloud into correct position
JRPcad
Hi All, I have some scan data which has been recently collected after I had already completed a lot of the project.
Can anyone give me some good advice on how to get the cloud to import at the correct location considering that I have already set up a shared coordinate system with AutoCAD survey drawings, which means the base point is many many miles away from the survey point. I'm also struggling to get the cloud to come in at the right orientation,
For some reason when in project north it gets inserted at true north and when in true north it rotates it the same distance as project north is rotated from true north, seems very strange.
Any help will be very appreciated - Thank you
I'm using 2013
For Architectural Services visit www.jrpcad.co.uk
Wed, Feb 6, 2013 at 3:46:58 PM | Importing Point cloud into correct position
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
So you already have other point clouds in your project in Revit but this one wont go to the right coordinates?
Wed, Feb 6, 2013 at 4:54:43 PM | Importing Point cloud into correct position
JRPcad
No theres no other point clouds in there already, the model was originally built from 2D CAD Drawings.
I've found a work around but it's very tedious:
I've realised that I can import into a new Project the cloud Origin to Origin. The cloud comes in asuming that the project base point is 0,0 (Surely it would make much more sence if it recognised the survey point as 0,0), so I get my Cloud people to change the ucs in the cloud to my project base point coordinates.
Then I import to a new project Origin to Origin draw a line from the Project base point directly verticle or horizontal, then copy and paste the cloud and line into main project at selected level (selecting a level with 0 elevation)
Then rotate the cloud and line at the project base point with the line as a reference to get it back to how it was in the new project. This gets the cloud exactly where it should be.
Although this all works okay it seems rather long winded, surely there is a simpler method or I'm missing something really obvious, i would expect to just link the cloud with Shared coordinates and it should import just like a CAD file. Oh just to add I have the exact same problem with a text fileswhen i use them for topo. Only when I specify a project North though, If I just work without selecting an aligned project north and leave project/true north alone, things import fine.
Point cloud importing
Mon, Aug 29, 2005 at 3:09:40 AM
Point cloud in Revit not moving smoothly
Mon, Jun 1, 2015 at 11:59:45 AM
Point Cloud in Revit 2014 no longer working in Revit 2015
Fri, May 15, 2015 at 3:23:06 AM
Revit 2014 Point Cloud Plot Issue
Fri, Apr 25, 2014 at 8:44:48 AM
Point Cloud location
Tue, Apr 8, 2014 at 2:23:56 PM
Page generation time: 1.3783
