Forums >> Revit Building >> Technical Support >> VG Revit Links (Internal)
Tue, Feb 5, 2013 at 1:52:08 PM | VG Revit Links (Internal)
cadman6735
cadman6735 Avatar
5 Stars: 4 Votes
I can't seem to find any informatoin on this...
Under VG Revit Links there is a [+] and under this is an (Internal) that also controls Revit Links, what is this for?
See Image
Thanks
  • Ability is what you're capable of doing.
  • Motivation determines what you do.
  • Attitude determines how well you do it.
Quote by:  Holtz, Lou
  • Life is all about the attitude
Tue, Feb 5, 2013 at 2:02:04 PM | VG Revit Links (Internal)
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
This additional check box is for each instance of the Link. If a link gets copied a new check box would appear. There can be multiple instances of a link in a project.
Here is a link to explain it further if needed http://forums.augi.com/showthread.php?114935-Revit-sub-link
Edited on: Tue, Feb 5, 2013 at 2:03:10 PM
Tue, Feb 5, 2013 at 2:30:46 PM | VG Revit Links (Internal)
cadman6735
cadman6735 Avatar
5 Stars: 4 Votes
I almost understand.  If I link in a model I get both the master and the Sub-VG (Internal) the internal doesn't mean anything and can be ingnored (per thread you directed me too), but if the link gets copied it create second sub-VG controller.  (which I tested and it does)
So now I have 3 Sub-VG, the Main, Internal and Not Shared, I can understand the logic because of Xrefs from AutoCAD, but I don't understand why it defaults to Main and a sub VG when the link is not copied then creates a second Sub with a copy.  And I am not sure who copies links anyway, the files we work with are so large that Revit Runs at snail speed anyway, copying links would be the last thing we would want to do.
Tue, Feb 5, 2013 at 2:35:09 PM | VG Revit Links (Internal)
cadman6735
cadman6735 Avatar
5 Stars: 4 Votes
If I didn't copy a link how would I use the (Internal), why would I use it?
Thanks
Tue, Feb 5, 2013 at 2:44:53 PM | VG Revit Links (Internal)
cadman6735
cadman6735 Avatar
5 Stars: 4 Votes
Ok, my buddy here in the office found the answer...  See attachment
Make perfect sence to me now, cool feature
Tue, Feb 5, 2013 at 3:05:18 PM | VG Revit Links (Internal)
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Nice link thank you, I will actually send this around my office because I know this question has come up before.
Revit Internal Parameters..?
Tue, Sep 14, 2010 at 10:51:15 AM
Trouble converting links to groups
Tue, Oct 25, 2016 at 12:12:21 AM
Internal Point, Line and Area Loads...Internal???
Fri, Dec 14, 2012 at 4:59:06 AM
MANAGE LINKS
Tue, Nov 10, 2009 at 7:41:25 AM
Internal Elevation Markers
Mon, Oct 25, 2010 at 4:32:30 PM
Page generation time: 1.2764
