Forums >> Revit Building >> Technical Support >> Curved Curtain Walls, Patterns, and Area Calculations
Mon, Feb 4, 2013 at 1:29:32 PM | Curved Curtain Walls, Patterns, and Area Calculations
cmrgaa
As I understand it, if you want a curved curtain wall with a pattern other than rectangular (hexagonal, for example), you have to apply the pattern to the modeled in place form.  However, you cannot use this object for area calculations.  A curtain system applied to a curved face can show area, but you are limited to a standard grid (as far as I know)
Is there some way to get the curtain system to recognize patterns other than rectangular grids?  I'm mainly looking for something that will allow me to have the pattern I want and the ability to be used in area calculations.  I know I can make the room separation lines myself, but with the shape evolving as the design progresses I figured this would be more efficient.
I'm also using revit 2013.
Thanks!
Mon, Feb 4, 2013 at 8:15:14 PM | Curved Curtain Walls, Patterns, and Area Calculations
alfmedina
alfmedina Avatar
4 Stars: 8 Votes
You need a room separation line, which is easy. The divided surface with curtain pattern will not serve as a room bounding element.
Planta1 Revit Online Consulting | info@planta1.com
Area Calculations
Fri, May 15, 2009 at 9:27:50 AM
Room area intelegance
Mon, Jun 2, 2008 at 8:44:47 PM
Curved Mullion within Curtain Walls
Mon, Oct 5, 2009 at 6:09:39 AM
ComCheck Energy program area calculations
Wed, Mar 26, 2008 at 11:38:06 AM
Aligning surface patterns on Curved walls
Thu, Mar 5, 2020 at 11:50:31 PM
Page generation time: 3.4414
