Forums >> Workflow & Implementation >> API & Third Party Apps >> Sketch Up to Revit
Mon, Feb 4, 2013 at 9:11:19 AM | Sketch Up to Revit
ReneeDLZ
Does anyone have any tips on importing a Google Sketchup model into Revit?  Any good place to start looking for information?
Mon, Feb 4, 2013 at 9:19:09 AM | Sketch Up to Revit
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
There are a lot of threads on this here just do a simple search and you will see all of the posts, or even look at the bottom of this page.  Also use your HELP as it explains how to do this.
http://wikihelp.autodesk.com/Revit/enu/2013/Help/00001-Revit_He0/0061-Start_a_61/0066-Using_In66/0070-Importin70/0073-Importin73
Edited on: Mon, Feb 4, 2013 at 9:20:15 AM
Mon, Feb 4, 2013 at 11:58:34 AM | Sketch Up to Revit
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
In a nut shell . . .
  1. Use Revit to create a family.
  2. Import the SketchUp file into the family.
  3. If you created the family outside the project, load the family into the project.
Then you should be able to 'Paint' the family surfaces with REVIT materials for rendering etc.
Mon, Feb 4, 2013 at 1:58:04 PM | Sketch Up to Revit
CDWdavid
5 Stars: 5 Votes
You can create families as mentioned by dgcad.
Here is the thread for how to control imported SketchUp objects color.
http://www.revitcity.com/forums.php?action=viewthread&thread_id=29146
Sketch up
Thu, Mar 15, 2007 at 6:46:50 PM
Sketch up to revit
Tue, Mar 26, 2013 at 7:31:17 AM
Question about sketch Mode
Thu, Jan 17, 2013 at 6:34:56 PM
Revit into Sketch-up?
Wed, Feb 17, 2010 at 1:08:26 PM
curtain wall sketch snapping problem
Wed, Aug 12, 2009 at 8:54:07 AM
Page generation time: 1.3296
