Forums >> Revit Building >> Technical Support >> Errors linking CAD into Revit
Wed, Jan 30, 2013 at 2:33:28 PM | Errors linking CAD into Revit
smithar06
Im using Revit 2012 and AutoCad 2012. I was using versions 2013 but my computer kept crashing. When I try to link my CAD file into Revit im getting an error that states, "could not be imported becasue of problems in the file. It may have internal errors or contain unreadable data created by third party applications." The CAD file that I am using is an exported 3ds Max file also 2012. I could use the help figuring this out I have a project due on Monday.
Edited on: Wed, Jan 30, 2013 at 2:34:42 PM
Adam R Smith
Wed, Jan 30, 2013 at 2:40:11 PM | Errors linking CAD into Revit
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
I misunderstood your post.  Do you get any errors when you open the CAD file?
Edited on: Wed, Jan 30, 2013 at 2:42:45 PM
Wed, Jan 30, 2013 at 2:41:52 PM | Errors linking CAD into Revit
Will this help? http://www.youtube.com/watch?v=ZghL7hRM-gM
Wed, Jan 30, 2013 at 2:53:52 PM | Errors linking CAD into Revit
smithar06
TeaFoe5: I do not get any errors when I open my CAD file.
WWHub: The issue with exporting my Max file is I want to be able to make changes in CAD that will automatically update in Revit. I do not beleive Max can do that. I may be wrong.
Adam R Smith
Wed, Jan 30, 2013 at 3:14:10 PM | Errors linking CAD into Revit
When CAD files are linked into Revit, you can use the reload option to update them.
DWG linking into revit
Mon, Jun 9, 2014 at 7:11:38 AM
Odd behavior when Linking AutoCAD
Thu, May 25, 2017 at 11:45:05 AM
Help: Aquiring CAD Coordinates/Linking/Multiple building drawing set/ Problems
Wed, Dec 19, 2007 at 5:06:04 PM
Problems linking DWG CAD files into Revit
Wed, May 14, 2014 at 10:33:52 AM
Linking a civil 3D CAD file to Revit Architecture 2012
Thu, Jan 12, 2012 at 6:48:02 PM
Page generation time: 4.3039
