14 Users Online (12 Members):
Forums >> Revit Building >> Technical Support >> Half Revit model greyed out in 3d mode
4 Posts No Rating |
I've never seen this before and I cant seem to fix it, the first and third levels are greyed out and the middle level looks fine. Does anyone know what could be causing this?
4 Posts No Rating |
I'm using Revit Architecture 2013.
Check your phasing
4 Posts No Rating |
I don't exaclt know what that means, sorry. I am pretty new to revit.
Read up on phasing in your help, it will be useful in future projects. Under Phasing in your properties you can set elements and whole floor plans to existing, demo, new construction etc. depending on what is set up. Go to your first floor plan and see what the phasing is set at compared to the second floor plan. In your 3D view try changing the Phase to project completion and see if they all end up looking the same.
4 Posts No Rating |
Thank you very very much, it worked.
Revit model half shaded half wireframe |
Mon, Dec 2, 2013 at 11:30:03 PM
Floor Model Pattern - Model option greyed out |
Fri, Mar 3, 2017 at 10:11:12 AM
Visibilty Graphics Greyed Out |
Fri, Nov 22, 2013 at 10:42:50 AM
Can I render in Family mode? |
Mon, Mar 29, 2010 at 6:37:04 AM
Question about sketch Mode |
Thu, Jan 17, 2013 at 6:34:56 PM
