14 Users Online (12 Members):
Forums >> Revit Building >> Technical Support >> Create topography from instance not picking up points
I have a site survey with 3D points marking the levels under a layer called T-Points, however when I import it into Revit & try to use the cad file to create topo from instance & use this layer it will not recognise the points. Can someone explain why as I am pretty sure I've used this before & it's picked up the points? (Revit '013)
Answer: http://www.revitcity.com/forums.php?action=viewthread&thread_id=16535&start=0
Thanks Typhoon, I would never have found that! Now I run the lsp routine & it gives me a points file that I then can use via the 'create from points file route' that is great - although I think i went wrong setting up the site project initially as now it's all over the place - luckily I have only put the topography in so can now do it properly with the correct points. I wish there was a plain English language instruction manual to tell you how to set up the site project in easy stages, the Help files are confusing to say the least!
Topography won't generate off points |
Fri, Oct 27, 2017 at 5:09:56 AM
How can you place a component's width by picking two points? |
Thu, Dec 22, 2005 at 3:42:01 AM
Topography points Crash in Revit 2013 |
Wed, Oct 31, 2012 at 4:34:47 AM
Topography Quality [ 1 2 ] |
Mon, Sep 21, 2020 at 7:51:10 AM
17
Exporting topography points from Revit to AutoCad |
Sat, May 23, 2015 at 11:21:41 AM
