Forums >> Revit Building >> Technical Support >> How to get high quality output in revit2011
Wed, Jan 30, 2013 at 3:00:36 AM | How to get high quality output in revit2011
Suresh1622
Pls anone let me know about get high quality output jpg from revit2011 also let me know how to set the accurate view
Wed, Jan 30, 2013 at 3:26:48 AM | How to get high quality output in revit2011
4 Stars: 205 Votes
Your question is not clear but render your camera views in High quality at 600 DPI's then export them.
Sat, Feb 2, 2013 at 6:01:18 AM | How to get high quality output in revit2011
Suresh1622
How to get accurate elevation view? also i cant get orginal rgp colour while rendering sir....................
Sat, Feb 2, 2013 at 7:39:42 AM | How to get high quality output in revit2011
4 Stars: 205 Votes
"How to get accurate elevation view?" - Still not clear
" also i cant get orginal rgp colour while rendering" -that's because the shadows, reflectivity, refractions, glossiness, highlights....
Thu, Feb 7, 2013 at 5:13:25 AM | How to get high quality output in revit2011
Suresh1622
Sir pls let me know how to give the setting for getting original rgp output........ pls share me with image format pls.......................
Thu, Feb 7, 2013 at 5:34:35 AM | How to get high quality output in revit2011
Suresh1622
Sir also i attach the jpg files....
001 its after rendering......
002 its  before  rendering.........
pls i got more trouble pls help me/////////
Edited on: Thu, Feb 7, 2013 at 6:19:08 AM
Thu, Feb 7, 2013 at 1:06:59 PM | How to get high quality output in revit2011
4 Stars: 205 Votes
Check the images please.
Fri, Feb 8, 2013 at 12:15:14 AM | How to get high quality output in revit2011
Suresh1622
I did like that only sir but the output doesn't came like true RGP...........Pls tell me how set the material to the wall.........
Fri, Feb 8, 2013 at 4:20:46 AM | How to get high quality output in revit2011
Suresh1622
Sir i had another one problem...... I dont have the tint option in my revit software, i am using revit 2011 thats y ah? pls give a solution sir pls.............. Also i attached one jpg pls check it out...........
Fri, Feb 8, 2013 at 4:57:50 AM | How to get high quality output in revit2011
4 Stars: 205 Votes
2011... long time... "play" with "Image Fade" and "Glossyness" values
Fri, Feb 8, 2013 at 5:36:17 AM | How to get high quality output in revit2011
#11
Suresh1622
sir i cant understood pls... how to solve my problems sir...........
Fri, Feb 8, 2013 at 1:22:16 PM | How to get high quality output in revit2011
#12
4 Stars: 205 Votes
To get the colours to look right we have to make the RGB values darker. Sometimes this means changing values between each render until it looks correct, ALSO you have the "Adjust Exposure" after render, here you can change some parameters like in Photoshop, play with that too...
Rendered products are not a very high quality
Fri, Mar 6, 2015 at 1:52:00 PM
High Quality Rendering Error
Thu, Mar 26, 2009 at 3:11:23 PM
Exterior/Interior Lighting in High Quality Rendering
Wed, Mar 18, 2015 at 4:16:33 PM
How to get natural photo rendering quality
Mon, Jan 7, 2013 at 3:58:35 AM
high quality, small size families
Fri, Mar 6, 2009 at 2:31:12 PM
Page generation time: 0.1083
