16 Users Online (14 Members):
Forums >> Revit Systems >> Technical Support >> Deleting Monitor on families issue
2 Posts No Rating |
Not sure what caused this issue, but we have a model that contains lights which were initially copy/monitored from a separate model. We're trying to copy and array the lights to other levels. However, Revit errors: stating elements can't be copied because they are monitored.
When fixture is selected the object does not contain a monitored icon, and the ribbon does not provide a delete/remove monitor option. I'm guessing that Revit maintains objects in monitor status although the original source model has been removed as a linked file. Is there a workaround to severe the monitor status without having to re-insert each fixture as a new element?
Is this what you are looking for?
http://wikihelp.autodesk.com/Revit/enu/2013/Help/00001-Revit_He0/2278-Collabor2278/2419-Multi-Di2419/2453-Stopping2453
2 Posts No Rating |
I appreciate the response. Unfortunately, the issue I have is not easily resolved via the wiki instructions. No "Unmonitor" option shows when objects are selected. However, when you try to copy the objects, then you get an error that the objects are "Monitored". Autodesk is currently looking into the issue and will post the results, if any... thanks.
Copy/Monitor |
Tue, Feb 12, 2008 at 2:37:43 PM
Revit 2012 in 1366x768 monitor? ... any issue? |
Sat, Feb 25, 2012 at 7:01:16 AM
issue with copy/monitor of space tags and numbers |
Tue, Nov 10, 2009 at 4:15:39 PM
Deleting Families from project file |
Thu, Nov 6, 2003 at 8:37:24 AM
Deleting Types From Filled Region Families |
Tue, Sep 9, 2008 at 6:56:41 PM
