32 Users Online (30 Members):
Forums >> Revit Building >> Technical Support >> Shakey Interface
I just loaded Revit LT 2013 (upgraded from Revit Architecture 2012) and I am experiencing a shakey interface everytime I select an object. When it stops jerking around the object moves several feet (or inches depending on scale factor. Is anyone else experiencing this?
Computer specs:
OS: Windows7 SP1
Processor: Intel Core i7-3630QM @2.4GHz
Memory: 8G
Video: Nvidia Quadra K1000M
I'd start by contacting your autodesk reseller with this one.
its the graphics driver, ive seen this many times.
If it's the same issue I'm having, (this is true for 2012 and 2013) what's happening is the options bar is disappearing/appearing. I don't have a fix for it, and it appears to be a graphics card issue. For me it only happens when I open a second project (families don't seem to cause it) in a single Revit session. It doesn't matter if I close the first project or not, if I open another project without restarting Revit it will happen. Selecting/deselecting an element once or twice without doing anything else seems to stop it, as does restarting Revit.
Also, turn off Press & Drag (lower right hand corner). This will at least keep you from accidentally dragging elements if it does happen unexpectedly.
Anti-aliased Revit/WIndows interface? |
Tue, May 22, 2007 at 1:27:45 PM
12
Stop the yearly interface updates |
Fri, May 13, 2011 at 8:38:20 AM
How can I change the font of the entire interface? |
Wed, Apr 13, 2011 at 3:02:56 PM
Revit Architecture 09 - User Interface |
Thu, May 29, 2008 at 3:27:12 PM
Revit Interface Class Outline |
Wed, Nov 2, 2011 at 9:45:35 AM
