Forums >> Revit Structure >> Technical Support >> Sloping Rafter & Analytical Line Connections
Wed, Jan 23, 2013 at 4:15:30 AM | Sloping Rafter & Analytical Line Connections
MartinGT
1 Stars: 1 Votes
Hi GuysWe are trying to model sloping rafters and have their analytical line tie up with the columns so we can plug it into some software. Its not noding correctly and could be because of the way we are modelling;I place a named reference plane on a slope. Then on plan draw my beam using the reference plane. This is fine. BUT I cannot node into the centre of the column, so the analytical lines do not tie up. Same with my bracing etc.Anyone help?
Installing analytical line into a in-place framing family?
Thu, Oct 15, 2009 at 2:37:44 AM
Adjusting the analytical line in a revit family
Fri, Mar 5, 2010 at 9:16:30 AM
Analytical Line
Tue, May 23, 2006 at 6:00:18 AM
Problem with adding analytical lines into Generic Model line template
Wed, Apr 10, 2013 at 3:31:06 PM
Analytical Modeling Issues
Wed, May 14, 2008 at 12:03:14 PM
Page generation time: 0.4833
