Forums >> General Discussion >> Revit Project Management >> Question about stair openings
Tue, Jan 22, 2013 at 8:10:25 PM | Question about stair openings
revituser24
revituser24 Avatar
3 Stars: 1 Votes
I need to have an opening on the 2nd floor.  My building is a 2 foor building. I need for the stairs to go from floor 1 to floor 2 only. Each floor is 9 feet high.
The stairs are a straight 45 degree angle. What are the steps to create that opening? After I create the opening which tool do i use to create the stairs.  Is it boundary, run, or riser?
Wed, Jan 23, 2013 at 6:52:27 AM | Question about stair openings
SDtairs do not create openings.  Your best choice is just to create an opening in your floor sketch.  Edit your floor.
Wed, Jan 23, 2013 at 8:26:11 AM | Question about stair openings
revituser24
revituser24 Avatar
3 Stars: 1 Votes
can I have some more details WWHub? Heres what I did,
1. - selected the 2nd floor 2.- clicked on edit boundary, 3.- sketched the opening, and then pressed "Finish mode"(green check mark).  After I did that, there is no opening on the 2nd floor.  I have looked at 4 or 5 different tutorials on how to create a basic floor opening, and each tutorial creates an opening differently, and it seems like the tutorials skip a few initial steps.
Wed, Jan 23, 2013 at 8:28:55 AM | Question about stair openings
Your process is correct as you posted it..
Do you also have a ceiling?  If so, you will have to sketch a hole in that as well.
Wed, Jan 23, 2013 at 8:34:54 AM | Question about stair openings
revituser24
revituser24 Avatar
3 Stars: 1 Votes
Hey WWHub. I want the opening on the 2nd floor. what does it mean to "create an opening in my floor sketch"? I am not sure if I am using the correct sequence of commands to sketch my floor .
Wed, Jan 23, 2013 at 8:55:29 AM | Question about stair openings
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
All you have to do is sketch your floor outline the way you want it then sketch another outline inside your floor outline that will be the stair opening.  It is all part of the same sketch
Wed, Jan 23, 2013 at 9:09:15 AM | Question about stair openings
revituser24
revituser24 Avatar
3 Stars: 1 Votes
yes I have a cieling on the 2nd floor.  The tutorial says to use the shaft opening command, but this tool from what I understand is for creating multiple openings at the same time.  I used the "shaft opening command" and it not only created and opening in the 2nd floor but created an opening through the foundation. That is not what I am looking for.  I just want an opening on the 2nd floor.
I am not sure sure which tools I need to use.  Heres a list of tools that may apply to me:  vertical opening, face opening, edit boundary, run.  Not sure of the sequence of commands.
Wed, Jan 23, 2013 at 9:21:26 AM | Question about stair openings
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
"Heres a list of tools that may apply to me: vertical opening, face opening, edit boundary, run."  NO
 You will do as we said.  Edit your floor and add another boundry where your stairs are (like the picture attached in my previous post), then Edit you ceiling and add another boundry where your stairs are (will look similar to my picture attached in my previous post for the floor)
Wed, Jan 23, 2013 at 9:25:27 AM | Question about stair openings
revituser24
revituser24 Avatar
3 Stars: 1 Votes
what are the sequence of commands to create a floor outline?
Wed, Jan 23, 2013 at 9:27:46 AM | Question about stair openings
revituser24
revituser24 Avatar
3 Stars: 1 Votes
How do I edit my floor and how do I edit my cieling?
Wed, Jan 23, 2013 at 9:35:47 AM | Question about stair openings
#11
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Click on your floor and and EDIT BOUNDARY, magenta lines will show up showing your floor outline, all you have to do is draw lines inside of those (where you want the opening) and you will get your opening.  It is the same process for the ceiling.
If you don't know how to create a floor you need to spend some time with your HELP
http://wikihelp.autodesk.com/Revit/enu/2013/Help/00001-Revit_He0/0328-Build_th328/0330-Architec330/0476-Floors476
Edited on: Wed, Jan 23, 2013 at 9:38:59 AM
Wed, Jan 23, 2013 at 10:06:33 AM | Question about stair openings
#12
revituser24
revituser24 Avatar
3 Stars: 1 Votes
I got the opening the way I want it. Thanks teafoe5 and thanks WWhub.  You guys deserve a promotion.
Fri, Jan 25, 2013 at 10:14:25 AM | Question about stair openings
#13
revituser24
revituser24 Avatar
3 Stars: 1 Votes
I need to determine what size opening is appropiate for my stairs on the 2nd floor.  Here are the details:
Total run of stairs = 13'-9"
Floor height = 9'-0"
Cieling hieght = 7'-0"
width of stairs = 3'-0"
12" carpet floor
What numbers do you come up with for the size floor opening for the stairs?
Fri, Jan 25, 2013 at 10:29:07 AM | Question about stair openings
#14
revituser24
revituser24 Avatar
3 Stars: 1 Votes
Also, The angle of the stairs is a straight 31.53 degrees from 1st floor to 2nd floor.
Fri, Jan 25, 2013 at 10:53:59 AM | Question about stair openings
#15
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Cut a section through your stair, then draw a detail line from the top of one tread to the next and offest it 7' up to find your minimum opening clearance.  With your dimensions I believe it is around 14'-0 3/8" long to get your desired head clearance with a 4" floor slab.  It will differ depending on your floor thickness. See image
Curved Stair Question
Mon, May 7, 2007 at 2:10:41 PM
Copy/Monitor Openings
Tue, Aug 9, 2016 at 3:41:46 PM
Very Simple question regarding openings
Sun, Jan 2, 2011 at 8:18:11 PM
Monolithic Stair Question
Thu, May 26, 2011 at 7:14:39 AM
OPenings through multiple walls?
Mon, May 24, 2010 at 4:48:54 PM
Page generation time: 2.0079
