Forums >> Revit Building >> Technical Support >> Rotating Fill Patterns
Mon, Jan 21, 2013 at 1:08:24 PM | Rotating Fill Patterns
my74porsche914
I applied a 1 hour fire rating fill pattern in a wall to turn on when in course mode, it seems to work well with horizontal and vertical walls
My problem is:
I have a door family that i have a generic annotation family (this family has the 1 hour fill pattern as used above)
but when I insert the door in a vertical wall the fill pattern stays like its in the horizontal postition
any ideas?
Mon, Jan 21, 2013 at 1:32:22 PM | Rotating Fill Patterns
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Use a Detail Component family to create your filled region instead of Generic Annotation.  You need to use a MODEL pattern type instead of a DRAFTING pattern type and you cannot create a model pattern type using the generic annotation family.
Wed, Jan 23, 2013 at 10:05:19 AM | Rotating Fill Patterns
my74porsche914
Teafoe, that worked
but now i have another issue that someone can shed light to, lol
I used a detail component that that has my desired model fill pattern inserted into my door family. In the door family I have that fill pattern with a yes/no parameter and visibility to show only on course mode.
wehn inseted into project, course mode show my fill pattern appears on screen shaded
but if I change to thin lines, it shows correctly
Wed, Jan 23, 2013 at 10:06:26 AM | Rotating Fill Patterns
my74porsche914
there is 2 images attached above
Wed, Jan 23, 2013 at 10:33:38 AM | Rotating Fill Patterns
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Does it appear correct in the family?  Can you attach the door family so I can take a look at it?
Wed, Jan 23, 2013 at 10:49:10 AM | Rotating Fill Patterns
my74porsche914
family attached below
Mon, Jan 28, 2013 at 7:41:41 AM | Rotating Fill Patterns
my74porsche914
I guess not luck
Mon, Jan 28, 2013 at 8:07:14 AM | Rotating Fill Patterns
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
It has to do with the scale of your fill pattern in your Detail Family.  It only shows at 1/16" and smaller, any bigger and it becomes one solid fill.
Mon, Jan 28, 2013 at 8:30:02 AM | Rotating Fill Patterns
Dafpfy
3.5 Stars: 11 Votes
Try this setting..
"There is no path to peace,
peace is the path."
Mahatma Gandhi.
Mon, Jan 28, 2013 at 8:34:03 AM | Rotating Fill Patterns
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
It is already set to the align with element setting. The problem now is the scale of the fill pattern.
Edited on: Mon, Jan 28, 2013 at 8:34:27 AM
Perpsective Fill Patterns
Mon, May 10, 2010 at 6:12:50 PM
Fill Patterns
Mon, Mar 10, 2008 at 6:40:09 AM
create/ convert hatch patterns (.pat) to revit fill patterns
Tue, Jun 2, 2015 at 11:29:00 AM
Fill patterns, where are they?
Tue, Mar 31, 2009 at 10:11:29 AM
Wall Fill Pattern question
Tue, Oct 23, 2012 at 8:39:37 AM
Page generation time: 0.7418
