Forums >> Revit Structure >> Tips & Tricks >> Solids
Mon, Jan 21, 2013 at 12:52:30 AM | Solids
revituser24
revituser24 Avatar
3 Stars: 1 Votes
I have revit 2012.  I have 2 different roofs that I want convert into 1 whole solid.  I am trying to create a sinlgle solid with a template roof and my own roof, so that when I click on it the entire roof highlights.
Mon, Jan 21, 2013 at 7:22:14 AM | Solids
revituser24
revituser24 Avatar
3 Stars: 1 Votes
I Joined a hip roof to a gable roof using the join roof command. Now I would like for the hip and gable roofs to be 1 in the same roof, so that when I click on it the entire roof highlights. Right now the hip and gable roofs highlight separately.
Mon, Jan 21, 2013 at 8:05:06 AM | Solids
If the roofs were made seperately, then they will be seperate.
You could group them but I don't know why you would.
Mon, Jan 21, 2013 at 9:24:49 AM | Solids
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
It is sometimes better to have seperate roofs and sometimes that is the only way to create a roof.  If you want to select all the roofs just click on one, right click and click select all instances in entire project.
cutting and slicing extruded solids ??
Wed, Apr 27, 2005 at 5:46:34 AM
Materials in imported solids
Sun, Aug 12, 2007 at 2:47:39 PM
Scheduling of solids within a family (Revit Architecture 2008)
Tue, Dec 4, 2007 at 2:35:55 PM
section view with imported Autocad 3d solids
Mon, Mar 17, 2008 at 9:17:01 PM
how to import solids of dwg as editable forms?
Fri, Feb 22, 2008 at 3:38:57 AM
Page generation time: 0.0263
