Forums >> Revit Building >> Technical Support >> Adaptive component facade profile
Wed, Jan 16, 2013 at 11:55:46 AM | Adaptive component facade profile
Tim79
Hi there,
I'm trying to create a façade profile as an adaptive component that can follow a mass volume.
The idea is to have up to a hundred of these profiles along a facade that change slightly each time to create the morphing form of the building.
In the attached file, the simple line family "Profile façade 7 côtés" works fine. But when I use the family that incorporates a profile "Profile façade 7 côtés 2" I can't get it to slide along the volume and adapt to the progressively changing form.......
I've been banging my head against a wall for a couple of days on this one - please help!!!
PS - I've thought about using divided surfaces, but not sure whether there would be a pattern that would suit it..... possibly rectangular?
Thanks in advance
Wed, Jan 16, 2013 at 4:34:34 PM | Adaptive component facade profile
alfmedina
alfmedina Avatar
4 Stars: 8 Votes
"Attached file" ?
Planta1 Revit Online Consulting | info@planta1.com
Adaptive component documentation
Wed, May 11, 2011 at 3:51:41 AM
Show user created dimensions within Adaptive Component in Sheets (2016)
Fri, Jul 1, 2016 at 1:55:50 PM
Adaptive Railing with Handrails
Thu, Sep 3, 2015 at 10:41:33 AM
Adaptive component multi-profile sweep (R13)
Thu, Sep 25, 2014 at 2:03:25 AM
Adaptive Component - Flaky Arc
Tue, Feb 9, 2016 at 1:26:48 PM
Page generation time: 0.1766
