Forums >> Revit Building >> Technical Support >> Floor level Heights Revised
Tue, Jan 15, 2013 at 8:58:22 AM | Floor level Heights Revised
prestijio
Hello Everyone,
Would like to say thank you in advance for any of your responses. I am having trouble with a project in which I have drawn floor levels at certain assumed elevations (ex. Ground floor at 0', Basement at -10.5', First Level at 12') I now have true elevation heights and want revise the elevations for each floor, basement is now 0, ground floor is now 10.5' and so on. Does anyone know of a way to change these without totally screwing up my model, is there a way to reassociated floor levels that doesn't affect the model? Your help will ge greatly appreciated.
Art
Tue, Jan 15, 2013 at 9:11:21 AM | Floor level Heights Revised
Start by dimensioning an elevation floor to floor and locking all but one dimension.  Change that dimension to what you want then lock it.  Now unlock - change - lock all of the otherdimensions untill it is correct.  Which dimension you change first is dependent on the model and you will have to figure that out.
By change dimension, I mean pick the associated level and the dimensions will be highlighted - now change the unlocked one.
Edited on: Tue, Jan 15, 2013 at 9:12:43 AM
Tue, Jan 15, 2013 at 11:58:49 AM | Floor level Heights Revised
prestijio
Thanks,
worked out well, had to do some minor fixes but worked out well.
changing multiple level heights
Wed, Oct 31, 2012 at 9:54:11 AM
Creating different floor heights on one level
Sun, Oct 11, 2009 at 7:54:06 AM
Topo Height vs Level Heights
Fri, May 13, 2005 at 3:25:34 PM
Apartment Groups - Ceiling heights
Mon, Jul 21, 2014 at 11:11:51 AM
Multi level stairs with different heights
Tue, Dec 10, 2013 at 7:10:57 AM
Page generation time: 0.3713
