Forums >> Revit Building >> Technical Support >> Bi-Fold Door Track Location
Tue, Jan 15, 2013 at 12:52:37 AM | Bi-Fold Door Track Location
raja15
Hi there.
I am currently using Revit 2012 on Windows 7.
I'm wondering if it's possible to change the "track" location of a bifold door using parameters available in the family. (See attached)
As you can see in the first diagram, the track is located "externally" which means that the bi-fold door would be completely exposed outside of the building.
In the second diagram, the track is located in the "centre" of the wall (200 Conc. Block used for this example) allowing the bi-fold door to be evenly exposed both internally & externally of the building.
We would like to have the flexibility to change this to suit each of our projects but I am a little lost as to how to go about it / if it can be done within the one door family.
If it is possible to do this, would it be better to use Symbolic lines which will change when the "external track" or "central track" is selected? Or would it be easier to simply use the 3D door panels which will be visible in Plan/RCP & When cut in Plan/RCP (if category permits).
I will be surprised if Revit allows you to do this other than creating two seperate families:
- One with the track externally
- One with the track central
If you have any tips or information available, could you please let me know.
Thanks in advance.
Tue, Jan 15, 2013 at 7:36:10 AM | Bi-Fold Door Track Location
Build your family around a reference plane that is initially well outside your wall.  Then add dimensions to this plane from the face of the wall and set that dimension to a label so you can modify it.
Bi - Fold windows...
Mon, Jul 2, 2012 at 8:24:37 PM
Bi-Fold doors parametrics for opening and closing 3d panels by percentage?
Wed, May 16, 2012 at 10:14:45 PM
Your opinions about this fold up door family
Wed, Jun 17, 2015 at 11:33:21 PM
Horizontal bi-fold door
Sun, Jun 1, 2025 at 2:02:13 PM
Weird thing inserting Bi-Fold door
Thu, Dec 9, 2010 at 12:33:56 PM
Page generation time: 0.2118
