Forums >> Revit Building >> Technical Support >> Wall hosted familes (simple question)
Mon, Jan 14, 2013 at 10:07:26 AM | Wall hosted familes (simple question)
leedeetee
Hi all,
My brain is frazzled today and I can't think for the life of me, how to achieve the following:
I have started to create some wall based familes, namely, some 2d electrical symbols.
I'm using the Electrical Fixture Wall Based template to draw my symbols, but how can I get my symbol to relate to the wall face and NOT the wall centreline? A thick wall eats up the symbol, a thin wall gives the symbol a big offset.
Apologies for such a stupid question, but I've tried help and googling to no avail.
Thanks.
Mon, Jan 14, 2013 at 10:17:31 AM | Wall hosted familes (simple question)
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
In your family group your 2D linework together and align and lock it to the face of the wall
Mon, Jan 14, 2013 at 10:20:10 AM | Wall hosted familes (simple question)
I personally don't like wall based families for these, I believe face based are better.  Then you can place them on different surfaces.
For your wall absed, start with a reference plane well off the face of the wall and parallel to it.  Build your family to this RP.  When finished, add a dimension from the face of the wall to the RP, set it to 0 and then lock it.
Mon, Jan 14, 2013 at 10:21:16 AM | Wall hosted familes (simple question)
I think groups are a big mistake here.  .... just the wrong application.
Mon, Jan 14, 2013 at 10:31:58 AM | Wall hosted familes (simple question)
leedeetee
Hi again,
Thanks so much for taking the time to reply - I knew it would be something simple. Still very much a Revit noob, so thanks again.
WWHub, thanks for the tip for face based families, but I'm sorry, I don't understand,  what do you mean about groups being the wrong application?
Cheers.
Edited on: Mon, Jan 14, 2013 at 10:33:59 AM
Mon, Jan 14, 2013 at 12:24:34 PM | Wall hosted familes (simple question)
Groups are meant to be used for multiple placement.  It is better to build this items and associate them with a plane.
Tue, Jan 15, 2013 at 2:45:24 AM | Wall hosted familes (simple question)
leedeetee
Thank you very much WWHub.
Wall hosted familes cutting through 2 types of walls
Thu, Oct 27, 2011 at 10:42:15 AM
Wall hosted Families
Wed, Feb 11, 2009 at 7:29:20 AM
Wall hosted Families question
Thu, Jan 3, 2008 at 7:04:01 PM
Wall hosted or Surface hosted
Mon, Sep 26, 2016 at 3:40:49 PM
Changing Wall Hosted components
Wed, Aug 1, 2007 at 9:47:34 AM
Page generation time: 2.3252
