Forums >> Revit Building >> Technical Support >> TitleBlock Labels
Mon, Jan 23, 2006 at 9:23:14 AM | TitleBlock Labels
elvis
Hi all, is it possible to create any new labels for the Titleblock, labels like progress print date etc. curious rel
Mon, Jan 23, 2006 at 1:55:38 PM | RE: TitleBlock Labels
arccodex1
3 Stars: 1 Votes
Sheet Issue Date is one of the pre-assigned labels but you can add labels like you'ld add any other family type. Label... Properties... Edit/New... Duplicate. The problem with these labels is that they are single line labels. It would be nice if one could create new labels like the Project Address Parameter (which allows for multiple lines). So, for Issue Dates we group text and copy the group onto all the sheets so that when you change one issue date all sheets are updated automatically. Hope that helps.
Wed, Jan 25, 2006 at 8:21:38 AM | RE: TitleBlock Labels
elvis
thanxs arccodex1, grouping and copying is helpfull but not very constructive, it is a workaround not. so it is a whishlist item? to make and format labels yourself, but who programmed the date/stamp label? it is kind of useless the create that label without any formatting issues! is it link to the computer system clock or so. hmmm, to bad, so revit could be disappointing aswell, thats new for meWinking grtz E
Labels don't show in titleblock
Tue, Jan 13, 2009 at 2:34:24 PM
Creating custom labels showing area in a titleblock.
Wed, Aug 7, 2013 at 10:40:49 AM
Titleblock Labels (Custom to each sheet) [ 1 2 ]
Mon, Oct 5, 2015 at 2:46:21 PM
21
Titleblock parameters / labels
Tue, Apr 7, 2009 at 12:41:34 PM
Revit templates
Sun, Jun 27, 2004 at 7:27:42 AM
Page generation time: 1.9866
