Forums >> Community >> Newbies >> Topography from sketchup zmap survey to revit???
Fri, Jan 11, 2013 at 9:41:40 AM | Topography from sketchup zmap survey to revit???
jpv89
I am trying to create a revit site model from this site model which was originally from sketchup (not sure if it was originally from sketchup but its the only file type I have). I imported it into autocad to create this dwg and I am attempting to create a group of masses for individual aspects such as the roads, ground, etc and being ale to assign different materials to them.
The only method I can think of is to create several sketchup models with the individual model categories and import them straight to 'in place masses'.
Any tips, hints or tricks would be greatly appreciated.
is anyone else wondering if or when revit will be capable of cutting a section through a dwg import or if its impossible???
Fri, Jan 11, 2013 at 9:46:55 AM | Topography from sketchup zmap survey to revit???
If the dwg import is in a cuttable family, it will cut.
Creating a topography from 3D CAD survey import
Thu, Feb 23, 2012 at 7:53:01 AM
matching contour lines from civil CAD when creating Topography (2019)
Fri, Dec 4, 2020 at 2:09:46 PM
Topography Elevation from Project Base and Survey Point is Incorrect
Thu, Jan 29, 2015 at 10:32:24 PM
Topography and Building relationship
Tue, Feb 23, 2010 at 1:22:08 PM
First post + terraced topography
Tue, Mar 29, 2011 at 9:12:35 AM
Page generation time: 1.6307
