Forums >> Community >> Newbies >> Need Gerneral answers to General questions
Thu, Jan 10, 2013 at 3:20:50 PM | Need Gerneral answers to General questions
Cage583
I am working on Revit (back and forth between 2011 and 2013) and I have been having a problem with my trees not showing up in my renderings. Any help would be much appreciated! And don't underestimate my inexperience with the program, it could easily be something you would think would be obvious. I am not very familiar with the program yet.  Thanks!!
Thu, Jan 10, 2013 at 3:25:07 PM | Need Gerneral answers to General questions
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
We need more information than "trees not showing up in my renderings".  Where did you get the family?  Do the show up on your site plan, or 3D views?  Are they not showing up in all of your projects in 2011 and 2013 or just one project?  Can you see the tree in the view you are trying to render?
Thu, Jan 10, 2013 at 3:32:40 PM | Need Gerneral answers to General questions
Cage583
I got the family from school. Our teacher has put a file out called "Revit Library 9.0". The trees show up in my site plan and 3D views. I can see the trees in the view I am trying to render until it is rendered. And I have not had this problem with the few other projects I have worked on. However; I am putting a "green roof" on the building so my trees and bushes are on my second floor elevation.
Thu, Jan 10, 2013 at 3:34:02 PM | Need Gerneral answers to General questions
9.0 TREES WILL NOT WORK IN 2011, 2012, 2013
Thu, Jan 10, 2013 at 3:51:39 PM | Need Gerneral answers to General questions
Cage583
Okay, Thank you. That explains it.
Thu, Jan 10, 2013 at 5:50:32 PM | Need Gerneral answers to General questions
Cage583
I got trees in just from the family that comes with Revit. But none of the shrubs are working, same problem.
Fri, Jan 11, 2013 at 7:35:00 AM | Need Gerneral answers to General questions
If you are working in either 2011 or 2013, the library families that come with that issue of Revit work.  Revit has a different render egine starting in 2011.  Prior revit foliage families and materials do not work after they switched the render engine.
Available trees should look something like the attached.  And your library should contain the families listed in the attached.
Fri, Jan 11, 2013 at 12:16:42 PM | Need Gerneral answers to General questions
Cage583
I don't have a problem with the trees anymore, just the shrubs. I used the families brought in by Revit but they still don't show up. And I ran into another problem on the way... How can I open a drawing that was drawn on Revit 2013 in Revit 2011?
Fri, Jan 11, 2013 at 12:42:31 PM | Need Gerneral answers to General questions
4 Stars: 205 Votes
Put some images so we can see what's the problem.
About the second question: NO, you CAN'T do that.
Fri, Jan 11, 2013 at 2:28:14 PM | Need Gerneral answers to General questions
Cage583
3D View
Rendering
Sat, Jan 12, 2013 at 5:13:42 AM | Need Gerneral answers to General questions
#11
4 Stars: 205 Votes
I opened your file and you don't have nothing in there so I can't see what's wrong with your shrubs... try to render in a "Camera view" and not in a 3D view
Wed, Mar 22, 2017 at 2:05:39 AM | revit link 3d view error
#12
dhivaharkumar92
hi am dhivahar,
   revit link 3d view was error.. how can i recover this problem. because revit link was inserted in MEP central file when i was opened some views file will ask fatel error , i have checked revit link if i go to 3d view file was asking fatel error..
How we go about getting answers to our Revit questions
Tue, Aug 26, 2008 at 12:59:35 PM
Please state Revit version being used in your questions [ 1 2 ]
Thu, Dec 15, 2016 at 6:32:17 AM
21
REVIT ANSWERS DIRECTLY
Mon, Jul 30, 2007 at 11:22:19 PM
Revit general questions
Wed, Jan 21, 2009 at 4:34:15 PM
Is this a Tips and Tricks forum or a side door to the General Discussion forum ?
Tue, Aug 22, 2006 at 11:05:45 AM
Page generation time: 0.8529
