Forums >> Revit Building >> Technical Support >> Floors not being cut in sections in 2013
Thu, Jan 10, 2013 at 1:17:19 PM | Floors not being cut in sections in 2013
ianOK
We just upgraded a project from 2012 to 2013. After upgrading, there are two floors which do not show up as cut in any sections (they displayed correctly in 2012). The two floors in question appear in the section, but not as cut elements (no cut pattern) and it is showing edges of the floor that should be well behind where the section is cut. One floor is 8" concrete and has been made to slope using the modify sub elements command. The other floor is a variable thickness floor modified in the same way to be the earth below the concrete floor since the topo is not nimble enough to folow the shape of the concret floor. Any ideas what could be causing this issue?
Fri, Jan 11, 2013 at 8:31:34 AM | Floors not being cut in sections in 2013
We do not yet work very much in 2013 because of some issues.
Have you updated your Revit to the latest update?
Create a new floor and edit it like you did this one.  If it behaves the same then it is a 2013 issue.
Fri, Jan 11, 2013 at 8:44:07 AM | Floors not being cut in sections in 2013
ianOK
Thanks for the response.
I tried remodelling the floors. No luck. Our structural engineer had copied the lake floor into their model which is linked into ours, so I deleted the lake floors in the structural model, reloaded it and then remodeled the floors again. And it worked... in only one of the dozens of sections that show the lake floors! So that's one more than before...
In one of the attached images you can see the sloping lake floor and the earth floor below it as it should appear and in the other image you see them both in elevation rather than section.
I can model it in a separate file, cut sections in that file and have it display correctly. If I insert or paste that into the main model, it goes back to displaying incorrectly.
Any other ideas out there in revit interwebs?
FLOORS W/ SLOPE ARROW DO NOT GET CUT WITH VIEW RANGE?
Thu, May 2, 2013 at 2:45:06 PM
Placed Sections on Sheet, Plan Cut Lines Disappeared, But the Sections Remain
Sun, Dec 2, 2012 at 7:34:52 PM
is there a way to make walls cut floors?
Mon, Feb 5, 2007 at 9:39:07 AM
Section line --goes up but not down
Mon, Jun 21, 2010 at 6:03:12 PM
FYI. Stairs showing through floors in REVIT 2013 [ 1 2 ]
Wed, Sep 23, 2015 at 2:57:56 AM
19
Page generation time: 0.9207
