Forums >> Revit Systems >> Technical Support >> Duct System problem
Thu, Jan 10, 2013 at 9:23:22 AM | Duct System problem
designimpressions
Hi, I created a Duct System comprising 6No. Air Terminals and a Fan Coil Unit. When I selected the System the 'System Inspector' didn't display on the Ribbon, I deleted the System and selected an Air Terminal with a view of creating a new System but the 'Create Systems' Panel didn't display on the Ribbon so I couldn't access the 'Duct' tool to create a new System. If I place an Air Terminal randomly and select it the 'Create Systems' panel with the 'Duct' tool appears. Anyone know what is causing this?
Thanks,
Peter
Edited on: Thu, Jan 10, 2013 at 10:20:32 AM
Fri, Jan 11, 2013 at 8:05:19 AM | Duct System problem
designimpressions
I discovered as a work around that if I delete and recreate a Flexi Duct the ‘Duct’ tool will then be active on the ‘Create Systems Panel’ and I can proceed with generating a new System and in return access the ‘System Inspector’...
duct system types
Fri, Apr 26, 2013 at 7:13:12 AM
11
Autocad MEP duct work question
Thu, Feb 17, 2011 at 11:12:01 AM
Duct Fitting Issue
Tue, Apr 1, 2014 at 1:16:35 PM
Side duct grilles?
Fri, Sep 28, 2012 at 10:52:50 AM
Help - Duct Callouts are relocating on drawing
Fri, Mar 27, 2009 at 10:36:57 AM
Page generation time: 2.9010
