13 Users Online (11 Members):
Forums >> Revit Building >> Technical Support >> Move/Copy/Align Masses
61 Posts No Rating |
Why is there such a bother to Move/Copy/Align Masses in Revit 2013? And how do you change visibility for masses so you see them in all views?
Kinda vague description of my issue but i dont know how to explain it better.
What is the problem with Move/Copy/Align that you are having with masses? Are you talking about in a project or in the massing environment? I have no porblem at all moving them. I also see them in all views when I bring them into a project. If you are not do you have a view template set to those views with massing off in the visability graphics?
They are In-place masses in a project. I think the problem was that they where multible masses grouped.
Thanks for your answer, i will try that template setting.
Copy during Align command? |
Wed, Sep 5, 2007 at 5:05:22 PM
Compare Two Masses in Schedule |
Fri, Jan 15, 2016 at 3:24:28 PM
Surface pattern move/align/adjust problems [ 1 2 ] |
Thu, Sep 17, 2020 at 10:29:33 AM
19
Revitcity downloads won't copy or move - files crash revit |
Tue, Feb 10, 2009 at 4:43:43 PM
Masses Don't Print?!? |
Thu, Feb 24, 2011 at 2:47:51 PM
