38 Users Online (36 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Building Elevations Looking Flat
Wed, Jan 9, 2013 at 6:49:00 PM | Building Elevations Looking Flat
TerribleTim
Ok gang, I know this has been a deeply debated topic, but here I am.I did a lot of internet searching and found lots of information on setting up the "Filter Method" to help make the elevations look less "flat". I even started trying to put it into use. That's where things went drastically wrong. I set up filters and then implemented them in the North Elevation. But what do I do when I turn the corner and I'm seeing the end of a wall in the West Elevation that is filtered for the North Elevation and I need it filtered something different in this elevation?This method seemed to work great as long as I only had one elevation.
Fri, Jan 11, 2013 at 9:37:35 AM | Building Elevations Looking Flat
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
For just that corner you could use the Linework tool
Fri, Jan 11, 2013 at 9:46:02 AM | Building Elevations Looking Flat
In my elevations, I will pick all elements that are back furthur - and over-ride graphics by element and screen them.
Fri, Jan 11, 2013 at 11:00:44 AM | Building Elevations Looking Flat
TerribleTim
Two good options, I hadn't thought about that, thanks!
New Member-flat/sloped roof problems.
Thu, Jul 9, 2009 at 2:43:41 AM
Elevations to Flat looking
Fri, Mar 6, 2009 at 2:37:25 PM
Placing building elevations
Mon, Jan 30, 2012 at 7:32:27 PM
Sloped flat roof
Mon, Jun 18, 2007 at 2:24:41 PM
EXCISTING BUILDING FILE AND NEW BUILDING FILE, HOW TO MERGE P.E. ELEVATIONS?
Tue, Apr 29, 2008 at 7:54:05 AM
Page generation time: 0.3183
