Forums >> Community >> The Studio >> can I model a rebar inside a model slab
Wed, Jan 9, 2013 at 12:09:31 PM | can I model a rebar inside a model slab
cephas5
5 Stars: 2 Votes
Hey I'm new to revit city I was wondering if it is possible to use revit architecture 2011 to model rebars like a 3d family inside a concrete slab so that when I cut the section through the slab I'm seeing the reinforcing model I need help plz
Wed, Jan 9, 2013 at 1:03:50 PM | can I model a rebar inside a model slab
Yes you can.
Good luck with your model's performance and file size!
I would never do it.
Wed, Jan 9, 2013 at 1:08:32 PM | can I model a rebar inside a model slab
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
I wouldn't either, just use detail components in your sections.
Wed, Jan 9, 2013 at 3:12:55 PM | can I model a rebar inside a model slab
cephas5
5 Stars: 2 Votes
K thanks alot I also Want to draw roof structural plan in revit but don't know how to even start
Wed, Jan 9, 2013 at 5:39:56 PM | can I model a rebar inside a model slab
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Modeling the rebar in the slab in REVIT Structure is quite possible and depending on the size of the model and how many slabs there are it's do-able. Modeling the roof framing is also possible by either concrete or steel joists.
Sounds like you have your work cut out for you. Have you had any training ?
Wed, Jan 9, 2013 at 6:51:13 PM | can I model a rebar inside a model slab
cephas5
5 Stars: 2 Votes
I've had some training but slab reinforcement Parametric in revit architecture is a first timer for Me do you think I cud achieve roof structural framing Plan in this program bcuz I don't av revit structure
Thu, Jan 10, 2013 at 8:18:31 AM | can I model a rebar inside a model slab
cephas5
Note that dgcad said Revit STRUCTURE!
Thu, Jan 10, 2013 at 11:49:50 AM | can I model a rebar inside a model slab
cephas5
5 Stars: 2 Votes
So do I av any chance of acheiving roof framing structure Plan in revit architect..…
Thu, Jan 10, 2013 at 12:29:27 PM | can I model a rebar inside a model slab
Sure you can but its like using a tack hammer to drive an 8d nail.  You can do it but it is the wrong tool.
Model lines not showing up on slab surface
Sun, May 1, 2016 at 8:30:20 AM
Rebar in a thickened slab Revit 2012
Thu, Dec 29, 2011 at 6:40:29 AM
Rebar Cover - Created Famil
Mon, Jan 24, 2011 at 7:50:19 AM
How much RST Rebar do people model ?
Mon, Jan 23, 2012 at 12:37:34 PM
Attaching walls to a Linked Structural Model slab
Mon, Nov 18, 2013 at 11:13:38 AM
Page generation time: 1.4341
